Old 05-14-2020, 09:26 PM
2nd67GTO's Avatar
2nd67GTO 2nd67GTO is offline
Default Minimum distance required? Fan, clutch and shroud.
So I’m tired of fighting warm cruise temps. Brand new build, 67 GTO, 467 stroker, Kauffman D-ports, Edelbrock water pump clearanced to approx .060 thou, March Style Track serpentine pulley set-up. Cold Case 1 1/4” dual tube rad, dual 12” Spal fans controlled by the FAST EFI ECU. 160 deg thermostat and Vintage Air. Runs 170 all day around town (haven’t Driven or ran AC on a Really hot 95+ day). Hit the freeway, 70 mph at 3000 rpm and she climbs to 195 in about 10 minutes. I realize those temps are fine, but ambient has been in low 70s. I can only imagine where the temps would go on a 90+ degree day.
After reading the multiple posts regarding lack of airflow with the CC shroud, I’m contemplating going to manual fan, clutch and shroud.
Problem is clearance Clarence! I only have 4” from the radiator core to the face of the water pump. Is this enough room for the clutch set-up and still maintain the half in, half out of the shroud for the fan? If not, what are my options?
Thanks for any advice or suggestions.
If it's worth doing, it's worth overdoing!
In the works; 400 based 468 Stroker. 4 Bolt mains, Fully forged rotating assembly, KB flat top, custom ground Comp hydraulic roller, KRE 85cc, 310 CFM heads, FAST multi port EFI.
Old 05-14-2020, 11:02 PM
Murf Murf is offline
Is there some reason you would have less room than a stock car? Motor & radiator are in their stock location?
I have a 65 with aluminum radiator & run a clutch fan & shroud. I can measure it for you tomorrow if it will help.
Murf
Sent from my iPhone using Tapatalk Pro
Old 05-15-2020, 12:39 AM
2nd67GTO's Avatar
Murf
Radiator is in stock location. The March serpentine system appears to move everything forward.
Knowing the stock distance would be helpful.
Old 05-15-2020, 01:37 AM
How well is the radiator sealed in the core support, ie. do you have all those little rubber flaps blocking the air from going around the radiator instead of thru it.
You issue of heating on the freeway is indicative of not enough air going thru.
Old 05-15-2020, 04:26 AM
2nd67GTO's Avatar
I’ve installed the complete AC rubber flap kit. The rad is sealed to the core support.
Old 05-15-2020, 05:34 AM
Geoff Geoff is offline
If it is getting hot above 70 mph, unlikely to be clutch/fan related. More pump speed needed [ smaller pump pulley ]. Pump should be overdriven 10-30%.
See:
www.stewartcomponents.com
Old 05-15-2020, 07:40 AM
The clutch fan is 3 1/4 inch as best as I can measure. My aluminum radiator is 5 1/4 inch from face of water pump pulley. I am surprised that system would eat up an inch but IDK. Mine is a 65 tho so maybe different too.
IDK how close you can run to the radiator, 3/4 inch would seem pretty close. I went back out & measured a stock clutch fan that came of the original motor it is 3 inches. The first one I’d a Hayden heavy duty clutch.
Good luck!
Murf
Old 05-15-2020, 07:42 AM
chrisp chrisp is offline
You have the tall core 17 1/2" & using the steel baffles ?
Old 05-15-2020, 09:58 AM
2nd67GTO's Avatar
Good luck!
Murf
Thanks for those measurements, I do appreciate you taking the time.
Sounds like it would be pretty tight. I found a short Hayden clutch, so all’s not lost.
I think the thicker pulley and pulley cover is where I lose the real estate.
Old 05-15-2020, 09:59 AM
2nd67GTO's Avatar
Yes, tall core and all steel baffles in place.
Old 05-15-2020, 09:43 PM
imposter's Avatar
imposter imposter is offline
Default clutch
whats the clutch # and do you have a 11 bolt pump
Old 05-15-2020, 11:33 PM
2nd67GTO's Avatar
Currently running dual electric fans. The short Hayden is #2947. Yes, the pump is the 11 bolt.
Old 05-16-2020, 11:20 AM
ZeGermanHam's Avatar
Is there any way you can even run a mechanical fan with the March setup that you have?
1998 BMW 328is (track rat)
Old 05-16-2020, 12:03 PM
2nd67GTO's Avatar
I don’t know, that’s why I’m asking for minimum distance. It appears that if I remove the WP pulley cover I can bolt the clutch in. I may have clearance issues with the AC and PS pulley covers.
Old 05-16-2020, 12:08 PM
2nd67GTO's Avatar
I’ve ordered the short Hayden HD clutch (#2947) and the Derale #17119 fan. Clutch will be here Monday, fan on Wednesday.
We’ll see!!!
Old 05-16-2020, 02:10 PM
We’ll see!!!
Good luck! Remember I’m pullin for ya. I’m sure you won’t have anymore cooling problem if you can fit it in there.
Murf
Old 05-17-2020, 01:30 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Just throwing an idea out there-
Is it possible that the electric fans cover so much radiator area that they restrict flow through the radiator at cruising speed? 55 mph should move a huge volume of air through a radiator- if not restricted. [No electric fan could free-wheel fast enough to keep up with 55 mph air]
Old 05-17-2020, 10:13 AM
Yes, that’s what I think is going on. I’ve seen it on other cars. I think that is why the OP is going to try a mechanical fan.
Murf
Old 05-17-2020, 12:55 PM
2nd67GTO's Avatar
After lots of reading here and elsewhere, the consensus seems to be the flat design of the CC shroud and the fact it's only 1/2” from the core blocks a lot of the air at highway speeds. The SPAL fans have a relatively small hub, so probably not the fan itself restricting the airflow.
Marshal
Old 05-17-2020, 12:58 PM
2nd67GTO's Avatar
Murf
Exactly! Thinking of ditching the shroud and strapping the fans directly to the radiator leaving the rest of the core to free flow while cruising. The more I look at things the less hope I have for getting a properly placed fan into a shroud.
Marshal
