Old 07-04-2020, 10:34 PM
wmurrell wmurrell is offline
1st week of April build, Pontiac, 3.90 rear, 4spd, HD radiator per PHS docs and the radiator has the plugs.
Old 07-04-2020, 11:54 PM
hobbygto65's Avatar
hobbygto65 hobbygto65 is offline
I had 65 Lemans 326 4 speed no plugs.
Old 07-05-2020, 08:46 AM
Big Bear's Avatar
Big Bear Big Bear is offline
The 65 tripower 4-sp 3:90 car I had, had the plugs in rad. Dont know for sure but most likely a Ohio built car.
Old 07-05-2020, 10:00 AM
GTO 68's Avatar
GTO 68 GTO 68 is offline
Default 1965 Radiator
My 1965 GTO built in Kansas December 18, 1964. 389 Cid, four barrel, manual 4 speed transmission, no p/s, no p/b, no a/c, petcock on driver side, radiator hoses on passenger side. No threaded holes or caps on lower tank of radiator.
Old 07-05-2020, 10:59 AM
I was told that Kansas City was a Chevrolet plant that built some Pontiac vehicles.
I was told that by a couple of Pontiac Plant Experts. Probably got the actual statement wrong. I personally do not know anything about Pontiac Vehicles Plant Histories.
I do know that KC did things differently vs Pontiac Michigan.
So GTO68, your post tells me that my April 1964 GTO with no plugs in the lower radiator tank (Manual Trans, Power Steering, No A/C, was still using "No Plug" Lower tanks until at least December 18, on vehicles they built.
Thanks for the info.
Old 07-05-2020, 10:03 PM
John V. John V. is offline
Tom, you might want to check my long post, your '64 got a Tall Rad.
And if it got a "no plugs" Man Trans specific Rad that was luck of the draw at KC in April '64. Check your Shipping Order doc for the Trans Code against the '64 codes I listed in my post. Presumably your Rad will match to the Code 159 (Code 59 on your doc) for the 2-5/8" thick Tall Rad without Oil Cooler.
Back then, the Car Divs controlled the Final plants and Fisher Body controlled the Body Plants, before the subsequent creation of the integrated GMAD to take on that role as the Car Divs became less autonomous car manufacturers and devolved to sales and marketing companies. So Tom, you are correct, the Kansas City A body Plant along with the Baltimore A body Plant were controlled by Chevy. Fremont was a BOP Plant and PMD alone controlled the Pontiac Plant. Rad codes are only shown on the '64 PHS docs for the KC and Balt Plants.
But other April or later KC builds like yours will show Code 58, the 2-5/8" thick tall Rad with Oil Cooler even with the Man Trans. There doesn't seem to be any rhyme or reason for it other than Rad availability.
'65 usage was very different as I outlined.
No A body Final Assembly Plant in Ohio for '64/'65. None in Kansas either. There was a big car Final Plant in Kansas City, Kansas but the A body was built at Kansas City, Missouri. Just wanted to avoid any confusion about radiator usage based on where the cars were built.
Old 07-05-2020, 10:25 PM
2-5/8" THICK TALL RADIATOR CODE 59 and if you remember which I am sure you do, I had the 3.90 rear axle ratio with metallic brakes. (No Power).
As I posted no plugs for a cooler.
Thanks for all of the help over the years.
Old 07-06-2020, 07:55 AM
Keith Seymore's Avatar
These are all consistent with the charts posted.
A bodies were built in Pontiac Michigan, Baltimore MD, Fremont CA and Kansas City MO.
K
'63 LeMans Convertible
'63 Grand Prix
Old 07-06-2020, 07:04 PM
geeteeohguy's Avatar
Just checked my late April 1965 Fremont built tripower 4 speed GTO that has the original Harrison 4 row radiator. It has the trans plugs in the bottom tank. They are slot-head and mount flush with the tank.
Jeff
Old 09-20-2020, 06:48 AM
rare4k's Avatar
rare4k rare4k is offline
Tag Id
Sent from my moto z3 using Tapatalk
