Old 02-15-2020, 04:13 PM
mgarblik mgarblik is offline
We were keeping the rpm under 8000 with the 4.5 stroke. Did the Grocery Getter weigh over 4000lbs?
No, it was just a tick over 3000#. I guess I have no idea what your cars weighs. Sorry for that confusion.
  #1782
Old 02-15-2020, 04:42 PM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
Hey Mike,
Raven race weight was 3640lb.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1783
Old 02-15-2020, 05:13 PM
cgeise's Avatar
cgeise cgeise is offline
just an FYI the guy that helped us tune our deal -- one of the best around at the time really liked the longer stroke easier to build boost he said -- BBC 632s run all day at 8k with a 4.75 stroke crank -- so --- go for it
  #1784
Old 02-15-2020, 05:26 PM
Hey Mike,
Wow! I had no idea it was that heavy. I know it has a tremendous chassis structure, but I never would have guessed that race weight. You are making allot of torque and HP to move that beast! Think about this: Your car may close to double the weight of the Kauffman dragster.
  #1785
Old 02-15-2020, 06:07 PM
PAUL K's Avatar
PAUL K PAUL K is offline
I like looking at things from different angles like that. The Raven can probably make close to three times the power also. I often show a novice the 1/8 mile MPH and compare it to current 0-60 times of performance cars today. It helps folks relate to how fast our cars are.
Go fast, see Elvis!
  #1786
Old 02-15-2020, 06:18 PM
slowbird's Avatar
slowbird slowbird is offline
Lol my father in-law didn't understand things until i put thing in terms of 0-125mph in 5sec. Then he seemed to sort of understand is Mercedes wasn't that impressive to me.
The Following User Says Thank You to slowbird For This Useful Post:
  #1787
Old 07-06-2020, 08:06 PM
RAIV-Z's Avatar
3/16th partial steel midplate replaced with ¼ aluminum full plate Hall's Custom
Done
Performance Torque Converters torque converter checked out and tightened up.
Done
Innovators West, Inc. damper internals checked out and larger hub machined and double keyed
Done
BOP Performance belt drive upgraded to a GEN-IV (Previous was a GEN-III)
Acquired
DEI Header wrap being replaced with Summit Volcano Wrap
Acquired
Fuel Injector Development 275lb injectors cleaned and reflowed
Done
ARP Automotive main studs being replaced with a new set.
Acquired
Crower Cams & Equipment Co .Crower Billet 4.5 being replaced with a 4.25
Acquired Moldex 4.25
ATI flexplate being replaced with a Meziere
Acquired
Composite distributor gear swapped out for a bronze Brian Hedrick
Acquired
Cam shaft replaced with one with a few degrees more duration.
Acquired
Ross Pistons Pins and Total Seal Rings
Acquired
Intake valve size increased from 2.270 to 2.280, Exhaust valves replaced
BME 396 Aluminum Rods
Acquired
Wastegates dumps relocated
Complete
ARP200 Head Studs
Acquired
DCI RAV Heads and intake being massaged by Jim Robertson.
Next up balancing and finish machine work on the short block.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1788
Old 07-07-2020, 12:41 AM
slowbird's Avatar
Good update, any idea when you hope to be running again?
  #1789
Old 07-07-2020, 11:23 AM
RAIV-Z's Avatar
Best case is looking like the end of August.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1790
Old 07-07-2020, 11:42 AM
GTOGEORGE's Avatar
What about DCI, I'm sure Don knows his heads better then anyone else?
GTO George
  #1791
Old 07-07-2020, 01:38 PM
Jim Robertson has a very good relationship with Don at DCI and has ported Don's heads for people over the years, with Don's blessing.
Plus I believe the current set of heads on the Raven were previously ported by Jim Robertson.
Ask the Raven guys about that deal George. I was in the Trailer when they talked to Jim Robertson years ago about him doing some heads for them.
  #1792
Old 07-07-2020, 01:42 PM
GTOGEORGE's Avatar
So another word you are just guessing.......good post!
Actually my post was to the Raven racing team!
GTO George
  #1793
Old 07-07-2020, 02:08 PM
Jim Robertson's Avatar
Jim Robertson Jim Robertson is offline
Yes we are making good progress on new port size/configurations. New seat work, guides, porting and Ti valves should help the Raven make a bit more steam.
For the record I have not seen or worked these heads and intake before but am looking forward to the opportunity to work on this extremely high quality engine/car build.
Stay tuned...
Jim
www.raceV8s.com
1972 Trans Am drag car, 3300lbs, 468 ci, Iron D ports, 428 block, 9799103 crank, 9.48 @ 143mph, 6.0 @ 114mph in the 1/8th.
  #1794
Old 07-07-2020, 02:53 PM
Thanks for the correct info Jim. Best to you and your family.
  #1795
Old 07-07-2020, 06:24 PM
3fastgtos 3fastgtos is offline
Were you having a problem with the composite dist. gear? I just ordered two of them. Lol
  #1796
Old 07-07-2020, 08:48 PM
RAIV-Z's Avatar
This composite gear was run for ~1.5 seasons driving a titan oil pump, It did look a bit chewed up. I will admit, the cam gear was not dressed prior to installation.
Name:	2020-02-01 16.29.02.jpg
ID:	544497   Click image for larger version
Name:	2020-02-01 16.28.06.jpg
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1797
Old 07-07-2020, 09:19 PM
GTOGEORGE's Avatar
What about DCI not porting you’re heads?
GTO George
  #1798
Old 07-07-2020, 10:09 PM
RAIV-Z's Avatar
GTO George
Hey George,
Don mildly ported the intake and heads when purchased. I had no plans on making any head changes besides increasing the intake valve size during what started out as a 2020 "refresh". At this point we were making ~1,828.07 flywheel HP based on the Wallace Racing calc at ~26.3lb boost. I do speak with Don and Jim as well as a few others regularly. While talking with Jim a few weeks ago I mentioned there were some major delays on short block parts and machine work, knowing that we want to really turn it up this year, he said send the top end down to him and he'll see what he could do to help out while turning around the parts in a very short time frame.
Btw, Jim recently also did a set of pump gas e-heads for Mike's 66 GTO "The Lunatic" that made 721hp.
ID:	544500   Click image for larger version
ID:	544501   Click image for larger version
Name:	2020-05-18 18.37.05.jpg
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1799
Old 07-10-2020, 07:10 PM
cgeise's Avatar
I may suggest a dry sump no dist gear issues then . I forgot to ask what is your A/F at during full throttle ???
  #1800
Old 07-10-2020, 08:58 PM
RAIV-Z's Avatar
Hey Curt,
No room for a dry sump at this time. Current target AFR is 11.8, at full throttle the O2 datalogs shows that AFR varies on both banks from 11.5 to 12.1
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
