Old 08-25-2020, 01:03 PM
Formulas's Avatar
Formulas Formulas is offline
Default Ram Air 4 pushrod strength
Searched archive's didn't find much info.
I have a new set of 11/32 RAIV pushrods that I bought 100 years ago at a HO Racing garage sale
What are the limits on these critters I know extra diameter over 5/16 is a good thing but at what spring rate / RPMs does the welded on ball split open the tube or the pushrod bends / fail at?
Anyone know wall thickness or material on these?
Were there very many failures in the OEM application's?
Old 08-25-2020, 01:39 PM
Skip Fix Skip Fix is online now
Are they the ones with a "Ball" welded on the end?
If so I bent one turning the motor over my hand when the rocker got in a slight bind on mock up.
Old 08-25-2020, 04:56 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Good pushrods. I wouldn't be afraid to use them with a mild solid roller.... About a hundred years ago they were a top shelf pushrod for us.
Go fast, see Elvis!
Old 08-26-2020, 05:57 AM
taff2's Avatar
taff2 taff2 is offline
I used them for 3 years without any issues on a 7000rpm 400, with Comp 995 springs on a solid flat tappet cam, so 140 on the seat and 320 open spring pressures.
Old 08-26-2020, 06:10 AM
steve25 steve25 is online now
The factory felt very sure of them to handle the 320 psi of open pressure that the springs used with the RA4 heads had at .519" net lift with a 6000 max rpm limit assuming the HO racing push Rods have the same level of quality.
Just keep in mind that with a 2.11" Intake valve your going to need at least 310 psi one the seat to run clean to 6000 rpm, especially if you running a more aggressive lobe, so if you want to turn more rpm, or your Intake valve is longer / heavery then the factory 5.200" valve lenght then you will need greater seat pressure and you will then be leaning on those push Rods a good bit more .
Old 08-26-2020, 08:00 AM
PAUL K's Avatar
I would NEVER use 310 lbs. of seat pressure with these pushrods..... That is at least 3/8 pushrod thick wall material or better!
Go fast, see Elvis!
Old 08-26-2020, 08:22 AM
slowbird's Avatar
slowbird slowbird is offline
I have to assume the 310lbs on the seat is a mix up? Assume you meant open psi? If not that's a crazy amount of spring for just 6000rpm
The Following User Says Thank You to slowbird For This Useful Post:
