Old 09-18-2020, 10:33 AM
Aluminum Chief's Avatar
Aluminum Chief Aluminum Chief is offline
Default 303 Ram V
Anyone ever see this???
Getting ready to assemble the short block and noticed this oil restrictor.
This pic is the upper saddle of #1 main bearing and the restrictor is threaded into the oil passage that goes to the pass side lifter galley.
Thanks KC
Old 09-18-2020, 10:39 AM
mgarblik mgarblik is offline
I have never seen that but after extensive study of the Pontiac oiling circuit, it makes sense.
Old 09-18-2020, 12:01 PM
I am not understanding that as according to my oil flow schematic I made a number of years ago the number 1 main hole in the block only feeds the number 2 rod Bearing and the number 1 Cam journal, am I wrong ?
If I am wrong then how are the driver's side lifters going to be restricted restricted other then in each lifter Bore?
Old 09-18-2020, 12:12 PM
PAUL K's Avatar
PAUL K PAUL K is offline
It will keep more oil to the bottom and less oil to the lifters on one side of the engine... High RPM road race conditions leave it in, street type deal or drag race I would remove it... JMO
Go fast, see Elvis!
Old 09-18-2020, 01:17 PM
Jeff Suchma here in Houston had a RAV block that had restrictors in all the cam bearing feed lines when he got it. I don't remember the history on that block.
Jeff at one time had a clone of the Gay Pontiac funny car but I never heard he completed it.
Old 09-18-2020, 01:21 PM
PAUL K's Avatar
A local guy here restricted all five cam bearings using a hole in the restrictor larger than the hole in the cam bearings.
Go fast, see Elvis!
Old 09-18-2020, 01:34 PM
slowbird's Avatar
slowbird slowbird is online now
How does that make sense?
Old 09-18-2020, 02:09 PM
I want to think I saw an article on a Mondello Olds build and their passages were similar and he used a restrictor there.
Old 09-18-2020, 04:18 PM
455-4+1's Avatar
455-4+1 455-4+1 is offline
Did not realise the factory (or other builders) did this.
We did the same on our 408 jetsprint engine for sustained WOT 6.5k rpm usage.
Restricted at this crossover galley, and redrilled / clocked cam bearings.
All our oil pressure was logged at the No1 main via a tube out the front of the block, not at the rear.
Working on going faster (and now staying dry at the same time !!)
Old 09-18-2020, 05:02 PM
Default 303
This block was supposedly owned by Buck Baker when he ran a 69 Firebird in Trans Am Racing which would explain the restrictor.
Paul K , I was thinking the same thing, remove it for street driving.
Thanks for the replies.
KC
The Following User Says Thank You to Aluminum Chief For This Useful Post:
Old 09-18-2020, 05:09 PM
PAUL K's Avatar
It doesn't that's what makes it funny!
Go fast, see Elvis!
Old 09-18-2020, 05:10 PM
PAUL K's Avatar
KC
I like that old school race stuff. Years ago I bought some RAIV heads and block that was owned by Tiny Lund.
Good luck with the project!
Go fast, see Elvis!
