Old 11-04-2020, 08:00 PM
4dr 4dr is offline
Default Steering wheel removal
66 lemans steering wheel will not come off using the puller.
Tried wd40
Its bending the bolts on the puller
Made a slight mess with the shaft and had to tool and die the shaft and nut
Will heating it up help
Thx
Steve
Old 11-04-2020, 08:29 PM
Old Goat 67's Avatar
Put tension on the the puller and tap the end of the puller shaft to shock it loose.
Always worked for me.
Old 11-04-2020, 09:00 PM
4dr 4dr is offline
Ok thanks
I’ll try it tomorrow and let you know
Old 11-05-2020, 02:42 PM
4dr 4dr is offline
Default Sw
No dice
I’ll try and restore it on the column.
If that turns into a cluster f, ill just put on a cover
Old 11-05-2020, 02:48 PM
ZeGermanHam's Avatar
Sorry for your frustrations. You may want to give it another try with some higher quality hardware if you're currently using lower grade stuff. Not saying it'll work, but I'd try all possible avenues of getting it off before giving up.
To answer your earlier question about heat, I wouldn't recommend using heat in that area. Maybe others will have other insights, but I wouldn't risk damaging the plastic and wiring with heat.
1998 BMW 328is (track rat)
Old 11-06-2020, 03:31 PM
4dr 4dr is offline
Yes it is an inexpensive puller from amazon.
The screw is bent
Thought i could get this off quick and have a winter project.
Old 11-06-2020, 07:52 PM
gtokid1968's Avatar
gtokid1968 gtokid1968 is offline
You should be able to rent a better one from any parts store. Let the WD-40 work for a couple of days.
The Following User Says Thank You to gtokid1968 For This Useful Post:
