Old 11-06-2020, 08:04 PM
Aluminum Chief's Avatar
Aluminum Chief Aluminum Chief is offline
Default 69 Firebird Shocks
Are rear shocks the same length for a mono leaf and multi leaf car or are the multi leaf shocks longer?
I realize the multi leaf shock must be a heavy duty type just wanted to know if the length is different.
Thanks KC
Old 11-06-2020, 09:37 PM
amcmike's Avatar
amcmike amcmike is offline
Thanks KC
They are different.
"The Mustang's front end is problematic... get yourself a Firebird." - Red Forman
Old 11-07-2020, 10:01 AM
Originally Posted by amcmike View Post
They are different.
Are they Longer?
Old 11-07-2020, 10:16 AM
amcmike's Avatar
I think the multileafs are longer. The lower shock mounts to the bracket underneath the spring pack. So more leaves means thicker, therefore the mount moves further away from the top mounting surface.
Most manufacturers carry two part numbers (one for monoleaf, one for multileaf) for that reason. They should be able to confirm which length fits which.
Old 11-07-2020, 10:20 AM
I think the multileafs are longer. The lower shock mounts to the bracket underneath the spring pack. So more leaves means thicker, means that mount moves further away from the top mounting surface.
That`s what I was thinking.
Thanks for the reply.
The Following User Says Thank You to Aluminum Chief For This Useful Post:
