Old 01-21-2021, 04:28 PM
hobbygto65's Avatar
hobbygto65 hobbygto65 is offline
Wow $345 for gasket style windshield and over $950 for glue in style.
  #362
Old 01-21-2021, 04:30 PM
hobbygto65's Avatar
Wow $345 for gasket style windshield and over $950 glue in style.
  #363
Old 01-21-2021, 06:57 PM
Doug Doug is offline
Angry ouch!
Was that quote from VINTAGE GLASS?
  #364
Old 01-21-2021, 07:40 PM
That extra 1/2" - 3/4" all the way around is costly.
  #365
Old 01-21-2021, 10:30 PM
tekuhn tekuhn is offline
Default Ashtray bulb holder
Originally Posted by tekuhn View Post
Is there a bracket that supports the rear of the factory radio? If so, mine is missing and I'd like to find one. It's currently only supported by the two front shafts. Thank you.
I found pictures of the radio support bracket, and it looks like it's just an "L" bracket, so I can probably just make one.
Also, does anyone have the small bracket that attaches the light bulb to the top of the ashtray (also for '63 - maybe all the same)?
Hoping to finish a project while I'm still able to push the clutch in....
1963 Tempest Convertible (Ram Air IV w/4” stroke), TKX, 9-inch w/3.70 gears and triangulated 4-link) Pictures
  #366
Old 01-22-2021, 01:18 PM
hobbygto65's Avatar
Apparently no one makes the larger windshield. So $ 995 is an nos one. Yes that was from Vintage glass.
  #367
Old 01-22-2021, 05:37 PM
c5farmer's Avatar
c5farmer c5farmer is offline
Default Windshield
Contact all the large glass company’s. They may have some setting in inventory. And cheaper than $900+.
  #368
Old 03-01-2021, 11:52 PM
Sanduners's Avatar
Sanduners Sanduners is offline
Default Convertible windshield trim
Looking for a right side top corner. Jim
  #369
Old 03-02-2021, 05:01 PM
hobbygto65's Avatar
Stainless trim for a gasket style windshield. 63 Sport coupe.
  #370
Old 03-02-2021, 07:43 PM
tom s tom s is offline
Need this trim piece for a 63 Lemans
  #371
Old 03-20-2021, 11:38 PM
Default Wanted - '63 Front License Plate Bracket
Does the '63 use a bracket to mount the front license plate? The previous owner of my car just had the plate attached to the upper two screws of the valence, but since there are also lower screws that are spaced closer together, I'm assuming there should be a bracket to mount it properly.
Just found this picture - looks like the bracket just attaches to the lower holes. I can probably make something to work, but would prefer a correct piece if possible.
  #372
Old 03-21-2021, 12:00 AM
mechanickeith's Avatar
mechanickeith mechanickeith is offline
The bracket, besides holding the plate, also moves the bottom of the plate forward so its straight up & down. Instead of slanting back at the bottom.
Keith Collier
61-63 Pontiac Tempest
Tech advisor
POCI.org
  #373
Old 03-21-2021, 12:50 AM
firefour1 firefour1 is offline
I have always wondered the same thing. If someone has one of these we can most likely copy and fabricate something pretty close.
  #374
Old 03-21-2021, 08:51 AM
Am seeing this on ebay this morning, it looks a lot like the bracket in the photo. Something like this may be close enough to work
https://www.ebay.com/i/200717142322?ul_noapp=true
  #375
Old 03-21-2021, 01:01 PM
Most likely that InlineTube bracket could be modified to work, but might be just as easy to start with a piece of flat steel or aluminum stock and bend my own. It basically needs to look like this from above with an angle bent into the inner straight piece to match the curvature of the valance.
  #376
Old 04-10-2021, 03:14 AM
MBLemans MBLemans is offline
Default manual transmission carb
Originally Posted by mechanickeith View Post
I have one for a manual trans car. Uses a Choke knob on dash.
Hey Keith,
How much did you want for the carb? Is it ready to bolt on or needing rebuilt? The one on my car is not original and is in need of a new base & rebuild.
Thanks,
Mark
  #377
Old 04-11-2021, 09:26 AM
Sorry looking for a 2 barrel carb for a manual transmission V8 car..
I didn't take the time to read over the entire posting.
  #378
Old 04-26-2021, 03:30 PM
Halfthrottle Halfthrottle is offline
Default 63 Lemans tail lamp bezel and fuel door.
Just took my tail lamp bezels and fuel door for re-chroming and was quoted $2000 because of how pitted they are. Looking for ones that are in half decent shape to be chromed.
  #379
Old 04-26-2021, 06:34 PM
Did you see my ad?I have a complete set that wont need to be rechromed except MAYBE the fuel door.Tom
  #380
Old 05-08-2021, 12:31 AM
katorocks katorocks is offline
I am looking for a 63 4bbl 4 cylinder air cleaner, front bumper, driver mirror, turn signal stalk, and distributor. Trying to revive this bronze beauty. Please help a lemans newbie out!
