Old 01-23-2021, 07:48 PM
performerrpm's Avatar
Default rod bearings
anyone know who makes a pontiac rod journal size, doweled rod bearing? trying to find some for use with bme rods but im not having much luck
Old 01-23-2021, 08:05 PM
AG's Avatar
AG AG is offline
Buy any rod bearing you like and have the holes drilled.
Old 01-23-2021, 08:22 PM
and i actually thought about that already...just for some unknown reason i guess i felt like i shouldnt do that😁
The Following User Says Thank You to performerrpm For This Useful Post:
Old 01-23-2021, 08:38 PM
mgarblik mgarblik is offline
Speed Pro 7050 CHA They are very hard to find since the advent of the aftermarket cranks that almost all have the 2.200 journal. The A designation means aluminum rod with the locating hole. I made a drilling fixture out of an old rod cap and drill them in the mill. Put a nice chamfer on the inside.
Old 01-24-2021, 09:45 AM
Be sure to have the proper size numbered drill bit and a spare before you dive in all the way!
Start off with a good amount smaller starter bit going thru all the way, and then use the needed size final bit and go thru from both sides of the bearing.
Do 2 practice runs on a old bearing if you have such, even if it’s a main bearing,
Old 01-24-2021, 10:21 AM
ErikW's Avatar
ErikW ErikW is offline
Back when I ran aluminum rods I made a drilling fixture from an old stock rod cap. Drilled through the cap at dead center. Helped to hold it securely in the drill press
1964 GTO
9.76 @ 137mph
2009 G8 GT
Old 01-24-2021, 01:02 PM
Scott Stoneburg's Avatar
So aluminum rods have a locator pin for the bearing to prevent spinning bearings? Why wouldnt this be used on steel rods too?
The Following User Says Thank You to Scott Stoneburg For This Useful Post:
Old 01-24-2021, 01:27 PM
Aluminum rods , even those hardend to T6 spects are so soft as compared to steel or cast iron / Armasteel that they can not develop the needed amount of bearing crush at the big and small end of the rods parting line to hold the bearing from spinning, plus Aluminums expansion rate is much higher then other rod materials when heated.
It’s the crush / compression of the bearing at the parting line that keeps any bearing be it main or rod from spinning, bearing tangs only serve to locate the bearing left and right in its bore.
Old 01-24-2021, 02:21 PM
Formulas's Avatar
Formulas Formulas is offline
This is how I did my BME bearings
I did the same as the other guys when I ran aluminum rods used an old rod cap.
Old 01-24-2021, 03:43 PM
thanks. my brothers a machinist so i think ill have him make me up a old rod cap as a template like was mentioned....otherwise ill have holes all my bearings an none in the right place
Old 01-25-2021, 08:53 AM
Gary H's Avatar
Gary H Gary H is offline
Also, I believe the Speed Pro bearing above was only produced in a standard size. No extra clearance, .010, etc. were available
Old 01-28-2021, 08:26 PM
Pontiac Performance Author
Order 1 dowel hole bearing, use as drill hole template in rod cap .
post # 4/6/9/10 : same way I did it before I got Mickey Thompson's bearing drilling fixture.
Old 01-28-2021, 08:59 PM
do u have a part no for a bearing? the one mentioned uo top is pretty much non existent bear as i can tell so if theres another out there you know of?
Old 01-29-2021, 06:18 PM
Formulas's Avatar
What size is your crank pin ?? I might have a set of .010 under Pontiac size rod bearings that were drilled torqued in but never ran
Also your going to want to verify dowel size to make sure no surprise changes there
Pulled them out of the deep freeze pole barn ACL brand about .181 dowel
Old 01-30-2021, 10:45 AM
my crank is a new forged crank so its still standard pontiac rod size. yea the dowel is not real big in tge rod cap, almost look like some kinda grease zerk at first to me since i hadnt ever seen a rod with them before
