Old 02-11-2021, 02:52 PM
DaleO's Avatar
DaleO DaleO is offline
Default Traction improvement suggestions?
After setting up a limited slip axle and adding slicks what is the next smartest thing a guy can do?
Old 02-11-2021, 03:01 PM
steve25 steve25 is online now
First tell us what body type you are making these improvements on, like is it leaf spring, or coil?
Old 02-11-2021, 03:20 PM
BILL BOWMAN1's Avatar
Go to the track, get a few back to back runs and then go from there
Old 02-11-2021, 03:31 PM
i82much's Avatar
i82much i82much is offline
Probably Blizzaks or maybe BFG all-terrains.
Oh wait, wrong forum ... my bad!
The Following User Says Thank You to i82much For This Useful Post:
Old 02-11-2021, 03:47 PM
4zpeed's Avatar
4zpeed 4zpeed is offline
Hope it don't rain....
Is this a street car?
Frank
Poncho Huggen, Gear Snatchen, Posi Piro.
Old 02-11-2021, 04:03 PM
Yes! In regards to the above post as far as going into a tight turn under hard throttle on a wet road, lol!
It’s a great way to go back to where you where headed from and get your knuckles instantly white!
BTDT a few times!
Ok back to your question.
Replace your hollow greasable stock type U- joints with race ones and then also add a driveshaft loop, this all assuming your driveshaft still has good wall thickness!
Old 02-11-2021, 04:49 PM
DaleO's Avatar
Duh, some data might be helpfull eh?
1967 GTO, 3.23, 428, TH400 with Cliff influenced 9.5 inch convertor. Rear sway bar/boxed control arms. Rear frame reinforcement bars. These noticeably stiffened up the car BTW. Factory replacement springs with coil over shocks which I suspect might be an issue.
Old 02-11-2021, 04:58 PM
In that case get a set of what’s called Hop Stop bars/ anti hop bars.
Also what’s the HP level planed for the motor, and or the ET you would like to turn in the 1/4 mile?
If your looking for making more then some 525 hp then fuel system up grades will be needed while we are talking about working on things under the car.
Old 02-11-2021, 05:05 PM
DaleO's Avatar
Steve25 - appreciate the strength and enhancements.
Steve 65 GTO - know where I can get a lift kit- ?!
Bill - I've had it to the strip once and did a best 13.582/103mph. Was with a stock convertor and marginal limited slip and limited experience : ) An error I think I did was to load up the trans just under 1,800 and "eased" it off the line and then laid into it best I could
Old 02-11-2021, 05:08 PM
Schurkey Schurkey is offline
That's a good start.
1. Replace the body bushings and whatever body bushing hardware is needed--probably all of it. The frame is a flexible mess until it's securely bolted to the body.
https://www.chevelles.com/threads/bo...-body.1131908/
2. Verify rear ride-height. The taller the ass-end is, the worse the traction is likely to be.
3. "Drag strip" traction is enhanced with tall, soft springs in front, and drag-race shocks. But that's a disaster on the street, which favors short, stiff springs for handling and braking. OEM springs are closer to the tall/soft drag ideal than to the short/stiff "handling" ideal.
4. My "A-body" '68 'Camino has No-Hop/Hop-Stop bars on the rear axle. Some folks don't like them, but I'm happy with 'em. Mind you, that thing hardly gets driven, and has never been to a drag strip. I plan to change that...someday.
5. A "posi"/limited-slip differential that actually works.
6. If the rear frame-stiffening bars made that much difference...I'd be looking for cracks in the frame.
Old 02-11-2021, 05:15 PM
DaleO's Avatar
I'll look up the hop shop's. Are they bolt on, is there any drilling needed?
Old 02-11-2021, 05:30 PM
DaleO's Avatar
Cracked frame, yikes.....I may have exaggerated a bit. I'm up on jack stands right now so will able to have a good look around.
When I put them on it wasn't addressing an issue as in feeling major loose or something like that, just thought if they were added for manual cars it won't hurt to add them here too.
I'm sure the body bushings have been there from the beginning and I can imagine new would really stiffen things up
Old 02-11-2021, 05:51 PM
Gotta drill the axle housing in the webs. There's more than one part number for the No-Hop bars, depending on which axle you're installing them on.
And you'll want to be careful about where in the web you're drilling, so the U-joint angles are correct when you're done.
The reason they were installed by gm to begin with was to "cure" a frame-cracking problem. It's worth a look on your frame.
Read the article at the link I provided. The run-on words and lack of proper bullet points is not my fault. I'm gonna have to jack them up about making some corrections. Point is, I could tell the car was more rigid just by jacking it up to take the jack-stands out when I was done installing the new ones. I didn't even have to drive it to notice the difference.
Fresh body bushings made a TREMENDOUS difference on my 'Camino. Keep in mind that the 'Camino has the "rigid" fully-boxed frame rails, and the frame is still a wobbly mess when it's not bolted to the body.
Old 02-11-2021, 06:26 PM
Navy Horn 16 Navy Horn 16 is offline
It's hard to put into words just how much better the Eaton Truetrac vs other styles of limited slip differentials. I highly recommend them.
77 Trans Am, 469 w/ported E-Heads via Kauffman, matched HSD intake, Butler Performance forged rotating assembly, Comp custom hyd roller, Q-jet, Art Carr 200 4R, 3.42s, 3 inch exhaust w/Doug's cutouts, D.U.I. Ignition. 7.40 in the 8th, [email protected] in the quarter...still tuning.
Old 02-11-2021, 07:31 PM
mchell's Avatar
mchell mchell is offline
Reminds me that I have to do something with my 50 year old body bushings
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile
Old 02-11-2021, 07:55 PM
DaleO's Avatar
Thanks Bill for body bushing replacement link. When I'm under there to put the trans back in, and looking the frame over for cracks/damage etc., I'll be noting body bushing interfaces for their condition.
Steve25, I missed your query about my goals. I want to be in the 12's and low would be great. I have to be sensible at this time of family raising so am ensuring I make responsible and efficient steps towards future "growth."
And folks, this is why I really appreciate your experience and insight.
Old 02-11-2021, 08:11 PM
4zpeed's Avatar
In addition don't forget to update control arm bushings.
Frank
The Following User Says Thank You to 4zpeed For This Useful Post:
Old 02-11-2021, 09:10 PM
lust4speed's Avatar
Seems like I've seen more frame flex than cracking. This photo is of a friend's '67 quarter panel. He had the factory 4-speed frame stiffeners in place since new but over time the bolts had loosened which allowed the bolt holes to hog out and effectively negate any ability to stiffen things up.
Anything over about 1-1/2" lift in the rear will get you into wheel hop. Best to stay close to stock control arm angles.
Name:	Quarater panel warp s.jpg
Mick Batson
The Following User Says Thank You to lust4speed For This Useful Post:
Old 02-11-2021, 09:28 PM
mchell's Avatar
Heads, cam, stall?
The next step is to run it again with a good tire under it.....you may not need any other improvement at the moment.
Just Guessing, but at your current power level with slicks you should have zero traction problems?
If you do find the need, you might want to loosen up the front suspension by removing sway bar, loosening end links, drag shocks etc etc as others have mentioned.
Fun times!
Old 02-11-2021, 09:43 PM
With slicks, this right here ^ ^ ^ is the best advice so far.
You'd be surprised just how easy a driveshaft can cut through a floor pan. If that happens you may never have to worry about trimming your toenails ever again. If you know what I mean.
The Following User Says Thank You to Chief of the 60's For This Useful Post:
