Old 05-05-2021, 12:51 PM
RocktimusPryme's Avatar
Default Vintage Air install question
So Im considering a VA Surefit kit for my 67 Firebird.
Normally I do most of my work myself, but I have zero interest in this particular job. Contacted a local shop who said that vintage air probably had a standard install time. They would charge me that number as a flat rate @ $110 per hour.
I thought that sounded pretty good until I got an email back from Vintage Air saying to expect 20-25 hours. Does that sound right? I was expecting more like 10-12 hours for a professional aftermarket shop.
For $1000 I was pretty happy to let someone else do it. For 2500+? That starts to sour me some on farming it out. I was even planning on buying it all through CVF and buying a serpentine kit with it to make it as easy as possible.
For those of you who have done it before or even better, shop pros who have installed multiple, whats the average time for one of the Surefit systems?
Old 05-05-2021, 01:16 PM
vertigto's Avatar
vertigto vertigto is offline
Semms excessive for an experienced shop, maybe it's an estimate for a hobbyist/newbie.
There is this...
https://www.camaros.net/threads/vint...nstall.154251/
Old 05-05-2021, 02:11 PM
Yeah, IDK, I didnt think it would take someone in a shop that long to do it.
Im not exactly a detail oriented person and I really wanted a clean install. Im more the type of dude whos gauges all work, but you can see the ugly wiring behind them. Thats why i wanted to farm it out. But the labor costs are making me rethink it. I might call them and offer $1500 in labor. See what they say. Much more than that and I really think about all the other cool aftermarket parts I could buy.
Old 05-05-2021, 02:55 PM
ZeGermanHam's Avatar
Yeah, 20-25 hours seems a bit excessive to me as well, but who knows. Maybe they are factoring in removal of the hood and fender to access the outer cowl and all the time needed for panel alignment.
I will soon be installing the VA SureFit in my GTO and I was planning to do the labor myself. It won't be fun, but there's a lot of things that I can buy with the money saved from not paying for installation labor.
1998 BMW 328is (track rat)
Old 05-05-2021, 03:17 PM
vertigto's Avatar
Is that estimate supposed to include routing AC ducting (if non-AC car)? Picking at straws...
Old 05-05-2021, 03:29 PM
No idea. Like I said I think I may call the shop and offer them a labor number I am comfortable with. Probably $1500. If they want it, great, if not, no hard feelings. Even that number is high and I would kinda be relieved if they told me no.
FWIW the shop told me that they would go with whatever VA said. Its VA that is being high on me here lol.
Its depressing because when the shop told me that I would be flat rated at $110 an hour I was happy. That was thinking it would be 10 hours though.
Old 05-05-2021, 09:26 PM
I like your approach of offering a number and leaving it at that. Not all projects are cut & dry with regard to billing. Some are more flat rate, and others can stay hourly. I don't know anyone who would pay $2750 (25hrs @ $110/hr) before taxes and incidentals to have A/C installed.
Old 05-05-2021, 10:03 PM
Lee's Avatar
Lee Lee is offline
I've put a few in. I'm happy charging $1,000 + supplies.
'73 T/A (sold). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 317rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'.
Old 05-05-2021, 11:39 PM
I have installed AC kits on new and old cars. It all depends on how much fabrication is involved and how neat a job you want. I haven't done any old car kits where the duct work fit worth a damn. I have always had to fab defroster ducts using part of the original, part of the kit and part I had to make myself. If you want a neat job usually the harness they supply will have to be modified too. To do the job right you either have the tools to make the hoses or you have to take them somewhere to have them crimped. The patches for the firewall need to be sealed when installed, left to dry and then painted. All this takes time. The better you want the finished product the more time it will take. Remember it's not their car so the only incentive the shop you hire has to do a quality job is money.
Old 05-06-2021, 08:33 AM
Thats the number I was expecting honestly.
As far as cost vs quality, that is a fair point. However, I would point out that if I decided to do it at home to save money, I dont have custom hose equipment either. So based on equipment, my version of the install is probably the by the manual lowest common denominator. So even if I got a shop to do it at a reasonable cost and they do a strict by the instructions install, it in theory would be at least equal to what I would do.
The only snags I think that would require some thinking is, Im guessing we would have to remove and reinstall my transmission cooler, and my fuel regulator is mounted to the passenger inner fender. So maybe slightly reroute that.
Old 05-06-2021, 10:24 AM
You can use the reusable Aeroquip fittings, or the Vintage Air EZ-Clip ones, clip plyers are required (not that expensive, buy the Aeroquip one), but if you want to use the crimp style, look up a hyd shop in your area, they will crimp them for you.
Vintage Air EZ-Clip fittings on Summit:
https://www.summitracing.com/search?...%20hose%20ends
Aeroquip EZ-Clip Fittings on Summit:
https://www.summitracing.com/search?...quip%20EZ-Clip
Vintage Air also has an assortment of pre-made hardlines too, as well as ones you bend:
https://www.vintageair.com/hose-kits...gerant%20Lines
You have to buy a line kit either way, you can just pay the difference and get the EZ-Clip line kit (It's about $200 more than the regular kit, but you save on install costs):
https://www.vintageair.com/hose-kits...at3=Hose%20Kit
It's really not a difficult project, a DYI-er can do it, there's really no 'custom' work involved, unless you want to deviate from the way the kit is designed to install.
Walk through the instructions, it's step by step, and has pics to guide you.
I used hard lines for some of the heater runs, it cleaned things up nice. I also used a bulkhead manifold, and depending on body, you may want to run the lines in a different route. Most f-body people choose the inline 4-port manifold, you can just drill the holes thru the firewall, maybe even the block off plate (pic is with a smoothy plate, but you get the idea).
Manifold:
https://www.amazon.com/LOSTAR-Alumin...0310955&sr=8-4
There's YouTube vids of installs you can use a reference, too.
Might take you a little longer than a shop, but the money you save, and the satisfaction of doing it yourself is priceless.
Old 05-06-2021, 10:28 AM
Unhook the regulator and lay it to the side, then remove the inner fenderwell. Run the A/C and heater lines behind the inner fenderwell/fender. After you reinstall the fenderwell, put the regulator back where it was.
You can look at my Judge build thread for ideas, but there are plenty of references out there to follow.
Old 05-06-2021, 11:04 AM
If you decide to do it yourself you can take your time and do a much neater job. I had the hoses for one of the kits crimped at a local AC shop and they only charged me $25 for all the hoses. I redid an Old Air install that another shop did. It blew cold air but that's about all it did. It came with 2 sections of wire harness. One with a 20 amp fuse and one with a 30 amp fuse. They connected them together and connected them both to a 15 amp fuse in the fuse panel. The hole in the firewall for the wiring looked like they made it with a hammer and chisel. All the extra wire was bunched up in a corner under the dash. Some of the outlets for the duct work were taped over and all the ducts had to be redone. Don't under estimate your work. You would NOT do that to your own car.
The Following User Says Thank You to Goatracer1 For This Useful Post:
Old 05-06-2021, 11:19 AM
I'm getting ready to do a VA install on my '71 bird, will use the inline manifold, and will keep the OE fresh air ducts, using non-AC kick panels. I prefer it that way.
VA did have some issues with the defrost adapters, no way they fit good, and I too used my OEs and modified. But that was not a surefit setup. The surefit setups generally have good adapters and other items.
I have a friend right now pulling his defrost duct adapters out of his kit he just got for a '68, he will send me info on those so I can share.
Old 05-06-2021, 11:27 AM
67-68 camaro/firebird evap kit install video:
https://www.youtube.com/watch?v=VjDquAIynWQ
Old 05-06-2021, 09:03 PM
randy1966GTO randy1966GTO is offline
I spent about 50 hours doing the Surefit VA kit on my car but that included quite a bit of work upgrading the dash and gauges and installing a stereo. I think 20-25 hours is spot-on and am happy that I was able to save that labor cost by doing it myself.
Old 05-07-2021, 07:17 AM
Thanks guys. Lot of good stuff here. Ill order a kit soon and see what shakes out. I think Im going to order a serpantine kit too so I may just order the whole thing from CVF. Unless someone knows where to get a significant discount on them. The kit seems about $1500 across the board.
Old 05-07-2021, 06:24 PM
Jonsey Jonsey is offline
I just finished installing a vintage air in my 69 firebird. It was a big job. For me, all the hoses were the right length and had the ends crimped on.
I didn't keep track of how many hours I spent on it, but it was a couple of weekends... definitely more than 10 hours. It is a nice piece of kit. Blower is strong and the air comes out nice and cold (or hot, depending on what you want.) All the hoses run up through the fender, so it looks very sanitary once installed.
Old 05-07-2021, 06:34 PM
Did you take pics along the way you can share? Pics I have are not really relevant, mine are diff body styles.
Old 05-07-2021, 06:41 PM
Looks like the only two pictures I took were of the controls conversion. Those are attached.
The car is mostly back together now, but I can take pictures of any other areas you're interested in.
ID:	566101   Click image for larger version
