Old 05-06-2021, 09:10 AM
chaosrob chaosrob is offline
Default Preferred Carb base gasket 1976 Trans Am
Looking see what you guys recommend for base gaskets on a 76 trans am with a 455, factory cast iron intake manifold and factory Quadrajet. Mine currently has a leak. and with all the options am. curious what is recommended. TIA
Old 05-08-2021, 07:41 AM
77 Canamman's Avatar
Fel-Pro has worked for me in the past.
https://www.autozone.com/fuel-delive...0397/67560_0_0
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
The Following User Says Thank You to 77 Canamman For This Useful Post:
Old 05-08-2021, 11:54 PM
x2 although not a Pontiac engine here, I find the thickest stock versions were the best, also for insulation purposes and those that include the nylon crush inserts.
Does yours also include the heat shield plate? Remember it will need gasket as well.
The Following User Says Thank You to Aus78Formula For This Useful Post:
Old 05-09-2021, 09:18 AM
burd's Avatar
burd burd is offline
No gasket on the stainless shield if you have one.
Just Say No To 8” Flakes pause pause
F ire B irds
Old 05-09-2021, 06:48 PM
I do not sir, thank you
Old 05-09-2021, 06:49 PM
Thank you sir. It does not have a metal heat shield
Old 05-09-2021, 06:50 PM
Thank you. I ordered two of them
The Following User Says Thank You to chaosrob For This Useful Post:
Old 05-09-2021, 07:34 PM
No gasket for the shield if it had one?
Old 05-09-2021, 09:12 PM
I'm not talking 40 years ago originality, I saying today, if it even had one it may need a gasket to seal those now warped and pitted surfaces. There were different types, no saying which his had if it did.
Old 05-10-2021, 05:00 AM
Lightbulb
GM parts catalog says otherwise..
498796:
