Old 10-25-2013, 07:32 PM
Drag Star Le Mans's Avatar
Default Rapid Fire-Blown 4 Banger drag car doing part time duty as a Salt Flat Racer...
Roger Manson from Canada runs his Rapid Fire Jeep of sorts at the drags to the tune of 8.70s over 150. He decided to run it at Speedweek and the guys from BangShift.com did a deal on it. Click the link to check it out.
http://bangshift.com/blog/rapid-fire...ho-banger.html
DragStarLeMans
The Following User Says Thank You to Drag Star Le Mans For This Useful Post:
Old 10-25-2013, 07:48 PM
Great Article. Thanks
Need to get back to Bonneville for visit #4. So many great people there.
Tom Vaught
Old 10-26-2013, 04:35 PM
mgarblik mgarblik is offline
That is a really nice article and great pictures. A cool blend of old and new tech. You can easily tell by reading the text that the author "gets it", he understands what the owner is trying to achieve. Impressive.
Old 06-28-2021, 06:48 PM
The engine from this little beast was on the dyno this weekend at Dave Bisschops of SD Performance. Little blown Pontiac ripped 597hp at 6300rpm.
https://www.youtube.com/watch?v=myV8cgPn3EY
DragStarLeMans
Old 06-28-2021, 06:54 PM
misterp266's Avatar
Wow, very cool! Just came across this post, too bad the bang shift link isn’t good anymore.
" Darksiders Rule "
Old 06-28-2021, 07:39 PM
Try this...
https://bangshift.com/bangshift1320/...poncho-banger/
DragStarLeMans
Old 06-29-2021, 12:54 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Thanks for posting this.
Old 06-29-2021, 01:36 AM
4zpeed's Avatar
4zpeed 4zpeed is offline
"He has made all of his major performance marks with a factory Ram Air II head on the engine. While the Edelbrock aluminum head is a good performer, Roger said that his old stand by which is a Pontiac Ram Air II iron head will be heading back on the engine because it is more beefy and holds head gasket seal better under boost than the aluminum piece."
Get back Roger! "Get back to where you once belong"
Very cool article, thanks for posting DragStarLeMans.
Frank
Poncho Huggen, Gear Snatchen, Posi Piro.
Old 10-25-2021, 12:16 AM
Here is another Manson engine on SD Dave's dyno. This is a 180ci 4 banger Pontiac. I think they went easy on it at 6400rpm. Roger said it buzzed to 7500 easy and still pulling.
https://www.youtube.com/watch?v=U-8TvYNNbQk
DragStarLeMans
Old 10-25-2021, 05:38 AM
JSchmitz's Avatar
JSchmitz JSchmitz is offline
Amazing power from this set-up. I've always been fascinated by this engine. Thanks for posting!
Old 07-09-2025, 02:16 PM
Another project coming out of the Manson shop. Roger had Hogan build this 4cyl intake to fit a 4/71 under the hood. The predator carb is only for show. The picture with two starters is more of a joke than anything. The lower one is what he runs on the Rapid Fire with a powerglide.
ID:	654089   Click image for larger version
ID:	654090   Click image for larger version
ID:	654091   Click image for larger version
DragStarLeMans
The Following 3 Users Say Thank You to Drag Star Le Mans For This Useful Post:
