Old 07-05-2021, 08:26 PM
padgett's Avatar
padgett padgett is offline
To attach a local picture (on your computer, you need to use the paperclip (local attachment). This board is odd.
Web Site
Old 08-01-2021, 09:33 PM
JPN_GP JPN_GP is offline
Small update with the GP, got the drum brakes back together and I'm moving on to replacing the brake lines that were damaged, fortunately there's only 2.
Old 01-07-2022, 04:25 PM
After quite a hiatus I finally got the brakes functional, so the car is at least able to move under it's own power. Next on the list I think is going to address the charging system, headlights, and taillights. The inline fuel pump is also temporary, the mechanical pump started leaking gas and I already have the electric pump since I used it to pump out the old gas in the tank. My goal is to get the car drivable so I can move it around if needed to work on it or other projects, I'm learning welding in my Autobody class so perhaps this year I might begin working on the rust, but we'll see how it goes.
