Old 09-03-2021, 02:19 AM
Default Non-TA buildsheet for Olds 350/403
Looking for anyone with a '77 350 Olds, or '77-79 403 Olds in a non-TA. Specifically, if you have the original buildsheet or perhaps a saved buildsheet for one of these cars but non-TA.
Wanted to confirm Box 53 on the Buildsheet, either factory was the same for this option. Likewise, if you still had an intact and readable original 'Keep you GM car...' aircleaner decal with part number or code....non-TA.
Old 09-06-2021, 03:53 AM
No rush.
Old 09-06-2021, 01:16 PM
Green Hornet's Avatar
Green Hornet Green Hornet is offline
FYI....Only one f-body build plant in 77......Norwood...
Old 09-06-2021, 07:27 PM
Yep, the question remains.
Old 09-07-2021, 10:10 PM
No, non-TA owners on here with an Olds? Or who have a saved pic?
Old 09-08-2021, 02:29 PM
With all due respect to your car...engine...and your interest in it....
77 Firebirds with 350 olds engines....were a California ONLY deal....if I am not mistaken.....which means that very few were sold.....and even less have survived...
I parted one out about 20 years ago....and was surprised to discover the engine was a 350 olds...and original to the car...
There are likely a few still out there....but the olds was prolly swapped out for a Pontiac 400....or sbc.....
Also the odds of finding a build sheet in a 70-77 Norwood build are NOT good...
90% of the cars I've checked had none.
Hope this helps......
The Following User Says Thank You to Green Hornet For This Useful Post:
Old 09-08-2021, 08:42 PM
Exactly why I posted it to ask others.
Old 09-08-2021, 11:22 PM
Good luck with that..........
Old 09-08-2021, 11:38 PM
Yes, the luck being with the contribution efforts of others. I have found 2, both with that section missing.
Old 09-09-2021, 09:46 AM
Ok found one, wasn't luck, just hours of searching. Thanks again guys.
Old 10-16-2021, 02:09 PM
Held for Ransom's Avatar
In case anyone wants the same info. It was PM 8996089. 1977-79 and I don't know if Norwood has the 99 in box 53 too.
ID:	575324   Click image for larger version
ID:	575325   Click image for larger version
ID:	575326   Click image for larger version
So long, farewell.
Old 10-16-2021, 06:23 PM
Thanks for the info and pics, appreciated. I'll have to check the one I found now to see if it had the 99 and what that refers to.
