Old 09-10-2021, 06:49 AM
helmerrock helmerrock is offline
Default Engine removal questions
I’m getting ready to pull the engine out of my 67 GTO I have a good 2 Ton cherry picker and the Mac tools tilter. I plan on pulling the motor and 4 speed Muncie together as a unit. Will I need to remove the starter? Should I take out the radiator? Can I leave the shifter on the transmission and just remove the stick? Any other tips besides plugging the tail of the trans. It’s been many years since I’ve pulled a motor and remember using a cheap come along. Now that I have better equipment I hope to pull the motor as complete as possible. This will likely be a one man Job as well
Old 09-10-2021, 07:22 AM
ErikW's Avatar
ErikW ErikW is offline
The starter has to come off. You really should pull the trans first as it will make engine extraction much easier but if you don't, yes the shifter should be removed.
1964 GTO
9.76 @ 137mph
2009 G8 GT
Old 09-10-2021, 08:45 AM
Gary H's Avatar
Gary H Gary H is offline
Yes, pull the starter and the radiator to be safe. When you hook up to the engine, grab it close to the intake so you won't have to lift it as high to clear the core support area. It's much easier to assemble the transmission to engine out of the car and reinstall than trying to line the engine up with a manual trans still in the car.
Old 09-10-2021, 08:48 AM
GoGoat GoGoat is offline
You will have to remove radiator. If doing this solo you might have to put temp weights on cherry picker, old heads work well. Make sure floor is level so doesn't tip sideways. Be carefull, go slow. Good luck.
Old 09-10-2021, 09:48 AM
Doug Doug is offline
1. scotch block car to keep it from rolling
2. make sure ALL wires are disconnected
3. disconnect speedo cable and back-up switch wire from tranny
4. grease up the threadbar on the tilter
5. remove distributor cap
6. buy a bag of kitty litter (you WILL need it)
The Following User Says Thank You to Doug For This Useful Post:
Old 09-10-2021, 10:43 AM
Jonsie Jonsie is offline
And remove the regulator from the firewall, no sense having the heavy engine bump into it during removal
Old 09-10-2021, 11:43 AM
Murf Murf is offline
I haven’t seen it mentioned & I suppose it depends on a lot of things but I remove the hood.
Murf
The Following User Says Thank You to Murf For This Useful Post:
Old 09-10-2021, 05:22 PM
tc's Avatar
tc tc is offline
If you don't have a spare driveshaft yoke to keep trans fluid from making a big mess, might want to drain the it and wrap the end.
Old 09-10-2021, 05:29 PM
Stuart's Avatar
Stuart Stuart is offline
If you have headers or long branch exhaust manifolds, unbolt them first - stock manifolds should clear. I don't recall having to remove the starter when pulling an engine, but it won't hurt to do so just in case.
Old 09-10-2021, 07:08 PM
FWIW- I'll never do this again w/o removing the front clip first. On the surface it seems like overkill, but the engine with the tranny attached will swing right out - no sweat. Really not too many bolts attaching the sheet metal to the body/frame. Hell, the hood and radiator w/the core are already out of the way. Whatever road you take, good luck
The Following User Says Thank You to Jonsie For This Useful Post:
Old 09-11-2021, 04:42 AM
Schurkey Schurkey is offline
If you insist on removing the trans with the engine, you will have to tilt the livin' pizz out of the engine/trans to get it to clear.
When the engine comes "up", the trans tilts "down".
You will need a heap of clearance under the back of the transmission. THAT means the whole vehicle has to be raised higher than you expect.
"I" would not pull the trans with the engine. But that's me.
The Following 2 Users Say Thank You to Schurkey For This Useful Post:
Old 09-11-2021, 09:57 AM
Old Goat Racer's Avatar
I always unbolt the tranny (400 turbo) starter, headers, carb, but NEVER pull the radiator !
Lift the motor straight up.
Your shifter will have to come off. And I would borrow an xtra pair of hands. Hand her a pair of gloves.
Everybody knows somthin.
Nobody knows everything !
Old 09-11-2021, 10:03 AM
I've done it a couple of times with the engine and (auto) transmission together. I had to lift the holy heck out of it but it did go. The leveler is your friend. And at least one other guy that knows what he's doing. Of course, these weren't concours cars. You could pull the core support along with the rad for a much easier go, not neccessarily pulling the whole front clip.
Old 09-11-2021, 10:04 AM
Yep! I always pull trans separately myself.
Old 09-11-2021, 10:10 AM
I would personally pull trans first only 4 bolts but if you don’t I would remove shifter or it’s going to ride floor all the way out. Without the trans you don't need the tilt just a motor plate and it will come out very easy.
Old 09-11-2021, 10:51 AM
Sirrotica's Avatar
Anyone that works on cars frequently, or as their profession usually leaves the transmission in the car when doing engine service that requires pulling the engine.
When I was just breaking into car repairs in my mid teens I used to pull both out together, later on I started pulling just the engine, and have not pulled both together for decades.
If I was pulling an engine, and transmission before sending a car to the scrapyard I could possibly pull both as a unit, but if it was in a car that I was going to return to service, the units would be separated. Lots less mess to clean up by leaving the transmission in the chassis, and lots less labor leaving the driveshaft and shift mechanism, cooling lines etc. intact.
As far as putting a manual transmission together with the engine in the car, it's not that difficult to do in chassis, done it many times, and you don't have to remove the shifter, and then reinstall it, so it save time, and effort. Working on cars for your living you find the most efficient methods of removing and installing engines, and transmissions, separating them in car is much more efficient, I've found, by trying it both ways, especially when it affects your paycheck. If you'd hang around a dealership very long you'd see that most people that make their living wrenching, leave the transmission in the chassis when pulling the engine for service. The exception would be if you pull the subframe, or cab on certain trucks out from the bottom on a chassis that can't be removed from the top, they both come out together.
Originally the factory installed the 2 units together, but the body hadn't been installed on the chassis yet either. The lift points that Pontiac engineers designed into the engine (RF tab on the timing cover, and hole on the left side of the block near the transmission mount surface) are designed to lift the engine only, that's how they engineered it from the factory, FWIW.
As a side note, I've seen a bet made that the guys in the GM dealership bet that you couldn't pull an engine, and re install it leaving the hood on, and the radiator in, yes it can be done................
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 09-11-2021, 01:47 PM
i always do them togeather as I don't have a lift and stabbing a trans or installing the clutch is easier done outside of the car. I left the shift linkage on, but you might need to prop the front tires on blocks as you need to tilt a good amount to get it to clear the tunnel.
2007 Grand Prix GXP 5.3L
Old 09-11-2021, 02:17 PM
nytrainer's Avatar
Anyone ever try to pull/stab engine with trans using a cherry picker type hoist while car is on a 4 post lift or quick jack? Thinking that setup could give needed ground clearance (maybe an additional 6-10”?) for the extreme tilt needed with trans attached. Then lift can be brought back down. The lift height of the engine hoist arm would be in question though.
Old 09-11-2021, 05:15 PM
Thanks for mentioning that.
MOST "engine hoists" sold in the last twenty years are pure trash. There were plenty of crappy ones forty years ago. Plenty of folks I talk to about engine hoists have never seen a properly-engineered engine hoist.
What is SOLD as a "2-ton" hoist is really a budget-built one-ton or even 3/4 ton hoist with a too-short lifting arm because a proper lifting arm would overwhelm the crappy, undersized hydraulic ram. They can call it a two-ton hoist only because the lifting arm (boom) is so tiny.
Which then means the entire hoist framework is small, thin and flimsy; but that makes 'em easier to ship from Asia.
I have two engine hoists. One came from Sam's Club decades ago; the other I bought when I moved--I needed a hoist at the old house; and another at the new place. The second hoist is another of the nameless, generic junk engine hoists that will barely lift an engine; and won't lift it very high because of the short, cheap boom. If you're pulling the trans with the engine, you're gonna need to lift the thing to the moon to get the trans over the radiator.
Here's what a real hoist can do: Cadillac 500, Turbo 425, suspension, steering, brakes, tires and front half of the frame from a '73 ElDorado. Consistent with safe practice, this is not anywhere near as high as it would lift, just enough to get it loaded onto the trailer.
(No, the crappy hoist at the other end of the road was not used to remove this from the trailer!)
ID:	572837   Click image for larger version
Old 09-11-2021, 06:00 PM
How I do it by myself in my garage.
Both the engine and trans were being replaced.
I simply rolled the car backwards little by little as I extracted the engine and trans rather than pull the hoist rearward. I always remove the radiator, why take the chance of damaging it?
The Mac’s Pivot Plate makes it so easy.
ID:	572844   Click image for larger version
ID:	572845   Click image for larger version
ID:	572846   Click image for larger version
ID:	572847   Click image for larger version
