Old 10-19-2021, 08:05 PM
DaleO's Avatar
DaleO DaleO is offline
Default HP/torque estimate
I know you guys are used to estimating numbers for the big engines but maybe you'd do a smaller engine?
1969 428 +. 030, 242 cfm 6X-4 (Dave B.), 800 cfm quadrajet (CliffR), 1967 intake. Engle 216/226 @ .050, .458/.468, 112 sep., HEI, Hooker Competition headers.
I have to run 91 octane in order to get 34 degree full advance so I figure I have at least 9:1 compression.
Thanks!
Old 10-19-2021, 09:22 PM
68WarDog's Avatar
68WarDog 68WarDog is offline
Cam kinda smallish for cubic inches. HP 385-390, TQ.455-465.
Old 10-19-2021, 09:28 PM
wild guess using a similar cam, 2801. and Jim Hand Ported Heads with 1.77 exhaust valve
2007 Grand Prix GXP 5.3L
4dblnkldude's Avatar
I say a tad higher. 398 HP and 469 TQ
Old 10-20-2021, 10:35 AM
Steve C. Steve C. is offline
Always good for entertainment.....
This thread and my post #15 here:
https://forums.maxperformanceinc.com...+Flow+Research
Regarding the total airflow delivered you might find this of interest and maybe helpful.....
Rocky Rotella and Jim Hand have done flow bench testing on how much a intake manifold reduces the flow to the cylinder head. Jim reports that a stock intake will flow about 91.5 to 92 percent of a ported head at 250 cfm. A Performer RPM will flow about 93.5 percent. I presume these are as cast intakes and not modified. Rocky has tested a RPM intake on a stock 5C head that flowed an average of 208 cfm at .500" lift and stock SD-455 head that flowed an average of 237 cfm at .550" lift. The RPM was a just under 93 percent with the 5C head and just over 92 percent with the SD head. If the percentage stays true as flow goes up, you'll need head flow in the 260 cfm range to get 240 cfm into the engine. Rocky used a as cast RPM intake and not modified. He also reports the RPM intake flows about 2 percent more than the average unmodified iron intake.
In addition to this there is restriction with the carburetor. He measured a QJ with those intakes and found his Holley HP950 and a Cliff-modified QJ each reduced flow by another 5 percent. If the QJ is stock the reduction can be as much as 7 percent.
Old information here:
Old 10-20-2021, 11:24 AM
DaleO's Avatar
I'm liking the estimates! They beat my thoughts of 300-325 hp and 400 ftlb.
I know I can use a bigger cam so am planning for that.
Those percentages add up but I'm sticking with the Pontiac pieces, at least for now. I appreciate the data.
Thanks a bunch guys.
-dale
