Old 11-06-2021, 07:25 PM
Originally Posted by markpj23 View Post
Do I still need the pull-off and linkage?
Mark,
Your carb doesn't have and doesn't use a front pull-off.
The one on the rear does it all.
Clay
  #62
Old 11-06-2021, 07:43 PM
NeighborsComplaint's Avatar
Originally Posted by Holeshot71 View Post
The big one in the front middle goes to the charcoal canister. If you don’t have one just cap It. The one to the left of that is for the choke pull off. You don’t have the pull off or the linkage that goes to the secondary air flap. You should have them both for cold start-up and to control the rate of opening for the secondary flaps. The other small one to the right is for ported vacuum to the distributor.
Look at the pic of the back of the carb. Choke pull-off is already connected.
Triple Black 1971 GTO
  #63
Old 11-07-2021, 10:51 AM
markpj23 markpj23 is offline
Originally Posted by "QUICK-SILVER" View Post
Mark,
Clay
Thanks - thought I was missing something...
Mark
Las Cruces NM
___________________________
Current Project:
'67 Catalina Convertible
400 4-spd
  #64
Old 11-07-2021, 11:09 AM
Rule of Thumb can be applied here!
Once a engine starts up cold, the choke flap should be pulled open ( by the choke pull off ) enough such that a 1/8” drill bit will just fit between the choke flap and the choke tower wall.
And depending on the Cam the high idle speed may need to be 1800 rpm.
  #65
Old 11-07-2021, 08:52 PM
Default Progress - But Still Lousy
So today I pulled off the Holley and installed the Qjet. Got the idle mixture adjusted for best vacuum but it still ran like crap, wanted to stall out, etc.
Rethinking where I started from, I decided to retard the timing again back towards where it was at the beginning. I didn't go too far back - it's now around 2 deg BTDC and running better. Idle is better but still not smooth. Went for a drive and response is WAY better when I put my foot in it, but steady speed still misses & bucks a bit.
One issue I have is too fast an idle even with the idle speed screw backed out all the way. Went for a short drive and the engine does not slow down as it should when the throttle closes. Checked the return spring and that's OK - a little weak maybe but OK. The choke plate is wide open so that's not the issue.
Once when I had the clutch in at idle the engine speed dropped and it stalled out. Restarted and it was back to fast idle again.
Is there an adjustment I'm missing or maybe I have a gasket interference problem? Closing the throttle by hand doesn't result in any more movement - it seems to close via the return spring the way it should.
Sorry this thread has been going for so long....
Mark
Las Cruces NM
Current Project:
400 4-spd
