Old 11-22-2021, 01:08 PM
Curtis Slowe Curtis Slowe is offline
Default New best
Went to a track rental. As usual I couldn't get the stuff that I wanted to do done like leaning it out (was 10.4afr), lashing valves, plugs, and reset timing. Anyway, this was leaving off 4.5-5psi with 5° of timing pulled and ramping to 14psi. I made a mistake and had my timing 4° down from where I wanted it. I think it would have ran a 5.6x or better leaner with a couple degrees more timing. Idk. Not hateful for a little over 3,800lbs.
https://youtu.be/jEZde6Ni4mc
https://youtu.be/L9thWMSdl58
ID:	578374   Click image for larger version
The Following User Says Thank You to Curtis Slowe For This Useful Post:
Old 11-22-2021, 01:30 PM
ErikW's Avatar
ErikW ErikW is offline
What's the setup?
1964 GTO
9.76 @ 137mph
2009 G8 GT
Old 11-22-2021, 01:53 PM
469", single TV8513 88mm, sft cam, self ported E heads, 9.3:1, CSU carb, th400, and 3.25 gears. I added a video.
Old 11-22-2021, 03:10 PM
73 TRANSAM 73 TRANSAM is offline
Looking good Ronnie!!!
The Following User Says Thank You to 73 TRANSAM For This Useful Post:
Old 11-22-2021, 07:57 PM
70 bird's Avatar
70 bird 70 bird is offline
Good work pays off! Nice job.
The Following User Says Thank You to 70 bird For This Useful Post:
Old 11-22-2021, 08:07 PM
ErikW's Avatar
Sweet
1964 GTO
9.76 @ 137mph
2009 G8 GT
The Following User Says Thank You to ErikW For This Useful Post:
Old 11-23-2021, 01:58 AM
R 70 Judge's Avatar
Nice pass. What fuel are you running?
James
1970 Trans Am
Old 11-23-2021, 05:18 AM
Scott Stoneburg's Avatar
Wow, that's awesome . Nice job on the combo.
Old 11-23-2021, 07:38 AM
It's on 93 pump gas with 1,000ml of water/methanol.
Thanks!
Old 11-23-2021, 07:41 AM
Thanks! I spent some time with the suspension and cage this year. Got tired of spinning. It's starting to come around.
Old 11-24-2021, 04:24 AM
RUDOLFSSON's Avatar
RUDOLFSSON RUDOLFSSON is offline
Good job !
The Following User Says Thank You to RUDOLFSSON For This Useful Post:
Old 11-28-2021, 10:03 AM
Originally Posted by RUDOLFSSON View Post
Good job !
Thanks! I don't think I've seen you post in a while. Is everything still good with you and your car?
Old 11-29-2021, 05:17 AM
RUDOLFSSON's Avatar
Yes.. not much of a poster these days.
Life is busy with three kids and big house renovations... car is still alive sort of but not in running condition as is
-Kris.
Old 12-17-2021, 08:26 PM
er455 er455 is offline
Default Nice pass
Hi Curtis did it run 9.80 in the quarter ? Did you let off because it said 98 mph . Slowe;6296845]Went to a track rental. As usual I couldn't get the stuff that I wanted to do done like leaning it out (was 10.4afr), lashing valves, plugs, and reset timing. Anyway, this was leaving off 4.5-5psi with 5° of timing pulled and ramping to 14psi. I made a mistake and had my timing 4° down from where I wanted it. I think it would have ran a 5.6x or better leaner with a couple degrees more timing. Idk. Not hateful for a little over 3,800lbs.
https://youtu.be/L9thWMSdl58[/QUOTE]
Old 12-17-2021, 08:56 PM
[QUOTE=er455;6303354]Hi Curtis did it run 9.80 in the quarter ? Did you let off because it said 98mph.
Yeah, let out at the 1/8. Would've gone 8.9x-9.0x in the 1/4.
Old 12-18-2021, 06:58 PM
Default Nice run
[QUOTE=Curtis Slowe;6303364]
Awesome , I have the a very simular setup but I am on E85 , what are you running for timing and are running race fuel ? Are you running a factory block ? I am just wanting to run mid 9 ,s in the quarter with a a full weight 79 trans am with A/c and overdrive (4l80e )
Old 12-18-2021, 07:25 PM
[QUOTE=er455;6303629]
I'm on pump gas. 93 octane and 1,000ml of water/methanol. It's a '71 455" 2 bolt block. Raceweight is about 3,830lbs. I made a mistake with the timing. I thought I had 38° in it for base timing but only had 34°. So I was pulling 11° for 27° but was actually at 23° because of the mistake. I checked timing before running and added 2° for my first pass for a 25° under boost. Got caught up in tuning the 60' and never did add more timing. Was planning on 28-29° at 14psi. Was also pulling 5° on the leave. Hope all that isn't confusing. Lol
Old 12-18-2021, 08:53 PM
Default New best
Thanks very nice set up glad to hear it a factory block too that what I have , no not confusing i have my timing locked at 28 at 14 # of boost
Old 12-19-2021, 07:13 PM
David Holmberg's Avatar
Great run! I've not run at Clay City in years, always fun there.
Old 02-27-2022, 08:57 PM
Default Timing retard
[QUOTE=Curtis Slowe;6303640]
Hey Curtis how are you pulling timing? thru a msd box ? I have a MSD 6 plus box and I will pull up to 10 degrees of timing but would you trust it to not fail ? Thanks
