Old 12-20-2021, 04:25 PM
penquin65 penquin65 is offline
Default 65 Console Shifter Boot Replacement
I need to replace the rubber shifter boot in my 1965 GTO. Do I need to remove the entire console or can you just remove the metal shifter housing to access the boot?
I appreciate the help.
Old 12-20-2021, 05:33 PM
Removing the console is not that big of a deal and it gives you easy access to the rubber shifter boot.
Old 12-21-2021, 08:55 AM
Andre's Avatar
Andre Andre is offline
You can't remove the housing without removing the console, unless you installed yours without the speed nuts holding it in place.
Old 12-21-2021, 03:42 PM
Thanks guys. I'll remove the console,
Old 12-21-2021, 06:01 PM
bob d bob d is offline
Default Shifter boot.
There is wiring harness under there so be carefull.
Old 12-22-2021, 09:07 AM
Thanks for the heads up.
Old 12-22-2021, 10:41 PM
Pecosbill's Avatar
Be sure you remove the two screws at the very forward top area of the console before you pull up on it. I’ve seen several where the person didn’t do that and bent and cracked the forward portion of the console trying to remove it while the two screws were holding it in.
Pecosbill
Old 12-23-2021, 08:19 AM
Default Light Harness
If your glove box light and rear courtesy if you have one don't work now is a good time to fix them. Bob.
Old 12-23-2021, 10:35 AM
Pecosbill's Avatar
Also, when you go to reinstall the console you may find that finding the screw holes in the floor pan through the carpet to be quite difficult. If that is the case, stick an ice pick through the screw hole in the console and then through the hole in the floor pan to line them up.
Pecosbill
Old 12-23-2021, 02:54 PM
geeteeohguy's Avatar
Good luck on the new boot. The new one I ordered years ago split in two in about 6 months and was so stiff it was hard to shift. I ended up re-installing the original boot and it's been there since. One small hole, but not bad for 57 years of service, and still shifts fine.
Jeff
Old 12-23-2021, 04:53 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
Default 1965 shifter boot with console
Here is a little more information on a ‘65 shifter boot.
This is an OEM Escutcheon, Seal and Plate that was pulled out of a 1965 Lemans 4 speed car with console.
ID:	580484   Click image for larger version
ID:	580485   Click image for larger version
ID:	580486   Click image for larger version
ID:	580487   Click image for larger version
