Old 12-19-2021, 07:17 PM
tom s tom s is offline
Going to drive out and pickup the lid to take to John to machine.Tom
  #382
Old 12-20-2021, 08:37 PM
scott70's Avatar
scott70 scott70 is offline
You win!77
I would of guessed you were younger.
  #383
Old 12-20-2021, 10:28 PM
So would I,dont feel that old!DAMN
  #384
Old 12-21-2021, 02:05 PM
421mike 421mike is offline
Send a message via Yahoo to 421mike
Default Bathtub
So how long to machine. Can't wait to see a finished piece. And Tom 77 is great, I don't look 79 however I might feel it a bit.
  #385
Old 12-21-2021, 08:20 PM
I picked up the top today and delivered to John to machine.Tom
  #386
Old 12-22-2021, 10:25 AM
mgarblik mgarblik is offline
That's a little Merry Christmas present to those of us anxiously waiting. So to understand completely, that top is a test casting made from the "production" tooling and "production patterns/cores?". Thanks again Tom.
  #387
Old 12-22-2021, 10:52 AM
Yes it is,next to the billet top it looks dead on.Tom
  #388
Old 01-05-2022, 11:06 AM
John machined it from the program the billet top was made from and it fit the billet bottom perfect.I tried to post pics on the core box tooling and core boxes but could not get them to load.Should have a intake casting to machine around the 21st of this month.Tom
  #389
Old 01-05-2022, 11:10 AM
scott70's Avatar
I should buy one just to stare at it.
  #390
Old 01-05-2022, 12:12 PM
darbikrash darbikrash is offline
The first production top casting is off the 5 Axis, and fit check with the billet base made from the same database. It fits perfectly. Should have the first early style base casting shortly.
1964 Catalina 2+2 4sp, 421 Tri-power
1965 GTO, Roadster Shop chassis, 461, Old Faithful cam, KRE heads 305 CFM,
Holley EFI, DIS ignition.
1969 GTO 467, Edelbrock 325 CFM, Terminator EFI
1969 Firebird Convertible
The Following User Says Thank You to darbikrash For This Useful Post:
  #391
Old 01-05-2022, 12:33 PM
tempest1964's Avatar
Bitchin'
  #392
Old 01-05-2022, 12:39 PM
JSuchma JSuchma is offline
I'm dumping alot into my RAV project right now, but if there is enough cash leftover, " I will buy one just to stare at!!! " 2022 is already looking to be a good year.
  #393
Old 01-05-2022, 12:45 PM
I already put you down for one Jeff!Tom
  #394
Old 01-05-2022, 12:48 PM
Thanks, Tom
  #395
Old 01-05-2022, 01:05 PM
Tom63LeMans's Avatar
Tom63LeMans Tom63LeMans is offline
Tom,
Please add me to the list for a 65+ manifold. I sent you a PM.
Thanks,
Tom
Tom
1963 Lemans -428 +.030, SD Perf KRE heads, turbo 350, 9" Ford 3:90, 11.01@121
1956 Chieftain gasser, 461 stroked 400, SD Perf ported E-heads, turbo 400, Dana 3:70 10.40@125
  #396
Old 01-05-2022, 01:17 PM
I put you down and replied to your PM.Tom
  #397
Old 01-05-2022, 05:27 PM
61-63 61-63 is offline
Question are what appear to be counter sunk cap screws just a function of checking the fit or is that the way production intakes will have the tops secured to the base? As I know you aware the real bathtub tops are secured with plain old hex head bolts.
  #398
Old 01-05-2022, 05:44 PM
Noticed that as well.
Not a feature I’d want on a reproduction of an old time factory speed part.
  #399
Old 01-05-2022, 06:54 PM
Bart,the intake we scanned had the counter sunk bolts so when it got scanned this is what we end up with.My Zajack-Johnson has the 1/4 bolts non sunk.These will be counter sunk and the change number will be dif.Early will be change 9 as I remember and the late will be change 10.Tom
  #400
Old 01-05-2022, 07:13 PM
I don't like it either but it is easy to fix just turn some aluminum sleeves down and insert them in the counter sunk holes and then run hex bolts through them. I want the intakes I ordered anyway.
