#441
Mike,the only reason I looked into a gasket is because Brad at Fabcraft had already made gaskets for the factory original intakes.He would have to get a new die made to produce these but he already has the contact to do it.Its going to be up to him if he thinks the juice is worth the squeeze.Anyone with a Xacto tool and a sheet of gasket material could make their own.Tom
#442
Like you said, 2 machined aluminum castings with plenty of bolts. A thin film of Hylomar, RTV, or even an anerobic sealer and your done. Doubt a gasket is needed. Can't wait for mine. Quick question as I get ready for it. What valley cover would you recommend for this manifold for the late model casting? The newest version with the front PCV or the mid 60's version with the rear PCV. Both are available new. Thank you.
#443
Both of mine have the early with the PCV going from the back to the fitting on the back of my front carb and PB going to the rear of the rear carb n my 62 GP.Tempest is on the lift has not PB.You can always drill and tap a pipe fitting for the PCV between the 2 carbs.Tom
#444
Tom, I noticed the mounting style uses the early narrow bolt pattern for AFB's at the carb bases and not a standard 4150? Assume these will not have both bolt patterns correct?
65 GTO, Tiger Gold, Nostalgia Super Stock 421, 2-Carter AFB carbs, Stock Suspension, 3550lbs Full Exhaust-- 9.70's@135 66 GTO (Retired race car) 421 CID Multiple NSCA/NMCA World Champion 66 GTO 389 3x2, 4 speed, 3.90 gear, Montero Red 33K original Miles 67 GTO 2dr Post, 428, Tri Power, 3.55 Gears 80 Trans Am Black SE Y84 W72 WS6 |
#445
No,only the AFB pattern.Will need a adapter to run Holleys.My intake came with the center squitters and adapter plates when I got it.No way around it.The Carter Competition and E carbs I believe have both patterns.Gaskets with both patterns are EZ to get.Tom
#446
This would be one of my choices for a carb.
https://www.ebay.com/itm/16526995385...4AAOSw35Be7r9w |
#447
Your 750 Carters should bolt right on?Tom
#448
I have a set of Carter Comp 750's to go on it and they do have both patterns. Just wanted make sure that people were aware.
#449
These make good 750 carbs also.Tom
https://www.ebay.com/itm/31381583802...UAAOSwQ51h0POw |
#450
Tom I believe he carb in post #446 has a passenger side fuel feed in the top. If so you don't want that if you desire the "correct" look, you want driver's side feed. 600-750 big top carbs are on ebay all the time a person just needs to watch for which side they want. Although the look is wrong passenger's side feed does make it easier to fab up linkage if a person does not have the real linkage.
#451
Guys,John and i measured a 5in top AFB and a 4in top AFB today from base of the carb too the air cleaner base on the carbs.The 5in top AFBs are .825 shorter than a 4in top AFB.This will help with your shoice of carbs if trying to get them under a hood.AC height will need to be added.As I said before that a 69 T/A intake screen will be the lowest to use.Tom
Tom |
#452
I dont know so I'm asking , would afb s from mid 60s Pontiacs work also? I have one plus access to others. Linkage from 63 Lemans be difficult to adapt? Last question which SD hood scoop should I buy small,medium(thinking medium), or large? Thanks
#454
Bob,if your going to run a open hood with a SD scoop you can virtually use any AFBs.DONT cut the hood until you have the engine in and intake and carbs mocked up.I have a factory Ford-SD scoop on my 63 Lemans.The 60s pass car Pontiac AFBs I dont believe are big enough.I think they are in the 500s,the 62-63 SDs are 625 and the SD NASCAR carbs are 750.John(61-63) could give you some buick and chevy numbers that are 625s.Tom
#455
Tom Thank you for the information on carbs and hood. That's what I need. I wont cut the hood. The Ford Super Duty scoop does give the car an 'image'. I can only imagine back in 62-63 the image!!
#456
Sometimes I feel like we are dealing with SMS!From a email today we are told we should have a early intake the end of next week for John to machine.I asked how soon on a late style.Still baby steps!Tom
| The Following 2 Users Say Thank You to tom s For This Useful Post: | ||
#457
If we were dealing with SMS they would have charged everyone's credit cards and been riding our float during the entire. process. Been there done that
| The Following User Says Thank You to 61-63 For This Useful Post: | ||
#458
Come on John, it only takes 2-3+ years to get your interior, more or less. 🤣🤣
| The Following User Says Thank You to 421mike For This Useful Post: | ||
#459
This thread started nov of 2020!Mike,if im going to Mammoth we could meet in between some where when yours is done?Tom
#460
Tom I’ll give you a call.
