Old 01-18-2022, 01:45 PM
GTOGEORGE's Avatar
EHTTFMF's!!!
Better then steel factory heads, that's for sure!! LOL!
GTO George
  #62
Old 01-18-2022, 01:47 PM
GTOGEORGE's Avatar
Paul,
Can you run more than 13 psi of boost with those? lol
Stan
I real question is do you need to run more then 13 lbs of boost? LOL!
GTO George
  #63
Old 01-18-2022, 01:57 PM
Stan Weiss's Avatar
GTO George
Is that laughter I hear from everybody other than you? Since this thread is about Tommy. What does he run? Maybe 3 times that 13 psi?
Stan
Pontiac Pump Gas List
  #64
Old 01-18-2022, 02:00 PM
J.C.you's Avatar
J.C.you J.C.you is offline
Looks like a 315 under his car on that 3.82 pass...anyone confirm? Video said that was initial shakedown this year.
1966 GTO dragcar
1966 GTO Ragtop
1969 GTO Judge RA lll, auto
1970 GP SSJ
Factory stock oval track car
  #65
Old 01-18-2022, 02:12 PM
opeliac opeliac is offline
GTO George
Only if you wanna go fast.
  #66
Old 01-18-2022, 02:17 PM
GTOGEORGE's Avatar
So what is fast? 90% (maybe more) of the Pontiac out there that don't run in the 7's NA and PA....just saying! TRUTH!
GTO George
  #67
Old 01-18-2022, 02:20 PM
GTOGEORGE's Avatar
Stan
Thats a good question i wonder how much boost he is running. 35-60 maybe?
I wonder if Tommy will have his 64 GTO with the Warp 6 heads on it at the Pontiac race at Norwalk this year?
GTO George
  #68
Old 01-18-2022, 02:21 PM
GTOGEORGE's Avatar
So what s the difference between the 315 and others?
GTO George
  #69
Old 01-18-2022, 02:40 PM
Stan Weiss's Avatar
GTO George
There is a 275 which is about 10.83" wide and a 315 which is about 12.4" wide. How wide a tire do you run?
Stan
  #70
Old 01-18-2022, 02:47 PM
John Langer's Avatar
John Langer John Langer is offline
Same weight, same cid, a Pontiac will never run with a hemi, 481x, bbc or bbf, period. IMO, the Pontiac can be competitive at the small block weights with either a 136 blower or twins. I would use a billet block with either the bes/butler pro ports or billet heads. I would lean towards a billet head with all of that cylinder pressure. The big but is, if you have a billet block and billet head that does not have the factory port layout, is it still a Pontiac? If you are buying billet pieces, why limit yourself to the Pontiac bore spacing. Just makes sense with your dollars to just go 481x or hemi.
  #71
Old 01-18-2022, 04:55 PM
GTO George
Are you asking that, while being serious? Or is there a joke in it that I didnt catch?
  #72
Old 01-18-2022, 05:19 PM
GTOGEORGE's Avatar
I don't do the street radial thing, so i never looked into them. I'm more curios into how wide the different sizes are........is there a problem?
GTO George
  #73
Old 01-18-2022, 05:38 PM
GTO George
With 50 years of experience, its hard to understand how you could not know anything about a 315 radial...It has pretty much taken the heads up world over...
3.5o in a door car...THAT is something that every racer should know about...
But, in your case, I understand
  #74
Old 01-18-2022, 05:55 PM
GTOGEORGE's Avatar
Lots of 3.50ish door cars in Pro Mod.....they run slicks....A Real Tire!
Never said i knew everything (no one knows everything) BUT i know what i know!
GTO George
  #75
Old 01-18-2022, 05:59 PM
GTO George
Actually, there arent lots of 3.50 door cars in ProMod...As for talking about a real tire...The 315 went a 3.50 at a heavier weight, and with no wheelie bars...It is in fact, THE BADDEST tire on a door car...
  #76
Old 01-18-2022, 06:02 PM
GTOGEORGE's Avatar
I have no wheelie bars! Still haven't answered my question about the tires.
Tommy runs 295's?
GTO George
  #77
Old 01-18-2022, 06:05 PM
Tommy runs 295's?
GTO George
You shouldnt need any George...But, keep in mind that we are talking about cars that run 3.50 in the 1/8th, not 5.05.
As for Tommy's tires...Last I knew, he was running Pro275...Can you guess what tire he should be on in that class?
  #78
Old 01-18-2022, 06:08 PM
GTOGEORGE's Avatar
......But why........its kinda STUPID all that power on a skinny tire looks like an accident ready to happen! Just saying!
GTO George
  #79
Old 01-18-2022, 06:10 PM
GTO George
Big tire cars with wheelie bars never crash? Just stop George, cause you are already making yourself look foolish yet again...
  #80
Old 01-18-2022, 06:14 PM
GTOGEORGE's Avatar
So what your saying is cars with 275 tires have no more accidents then cars with slicks that are wider.......you know normal tires!
GTO George
