Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 01-27-2022, 12:59 AM
Jim Robertson's Avatar
Jim Robertson Jim Robertson is offline
Default Wanted: 1971 HO heads #197, intake and crossover
Looking for a pair of ‘71 HO heads. Ported heads considered. What is out there?
Intake manifold and crossover (originals) preferred. May consider a reproduction intake with correct casting numbers.
Thanks,
Jim
Jim
www.raceV8s.com
1972 Trans Am drag car, 3300lbs, 468 ci, Iron D ports, 428 block, 9799103 crank, 9.48 @ 143mph, 6.0 @ 114mph in the 1/8th.
Old 01-27-2022, 09:18 AM
Uncle Judge's Avatar
Uncle Judge Uncle Judge is offline
Thanks,
Jim
Jim I’ll take a look and see what I have available. I have plenty of original 1971 HO parts.
You don’t want a reproduction intake either. The fit/quality is extremely poor.
Do you need these parts for a restoration? Feel free to email me directly. Thanks, Jeff
Old 01-27-2022, 10:00 AM
chuckies76ta's Avatar
Hi Jim: I have set here if your interested. Shipping cost would be probably high. Would have to go truck freight. https://forums.maxperformanceinc.com...11#post5978911
950 Quickfuel.
Old 01-27-2022, 10:17 AM
A set on Ebay.. https://www.ebay.com/itm/28454111993...wAAOSwBnxhnb5x
950 Quickfuel.
Old 01-27-2022, 06:34 PM
Jim I will second on repops being way off but nothing some TIG weld and remilling usually can't fix. But they do not look perfect in the casting number area, so if going for a numbers matching I'd hunt up a factory intake.
Old 02-04-2022, 05:46 PM
70KGOLD's Avatar
70KGOLD 70KGOLD is offline
Default 197 engine
I have a complete running 455 std bore with 197 heads. Block is not correct date. Heads and intake are correct. I have it for sale. Price is 6500 firm. Thanks.
