Old 02-14-2022, 09:38 PM
opeliac opeliac is offline
Originally Posted by GTOGEORGE View Post
I think the rings Marty used on his car would be good for a low HP application 1,200-1,600 HP but when you get in the upper HP levels like around 2,000 + a hoop set up like Steve Morris has would work a lot better.
I'm lucky my dual o-ring set up with my ARP2000 studs work fine ill see what happen this year.
GTO George
I hope you are wrong on that...I am planning to run them and am expecting to make north of 2500.
  #42
Old 02-14-2022, 10:47 PM
johnta1 johnta1 is online now
Link to thread on rings:
New Head Gaskets
  #43
Old 02-15-2022, 07:31 AM
GTOGEORGE's Avatar
I’m thinking Marty’s gas filled rings are more for a lower Hp level……under 1,600hp. Going by my research Steve Morris Hoops work for a higher hp level…. Over 1,600 hp. Just wondering what’s the known hp level Marty’s rings have held up to?
GTO George
  #44
Old 02-15-2022, 10:38 AM
Stan Weiss's Avatar
Interesting how some people don't understand how things work and should be rated. The rings don't know a thing about HP. They control cylinder pressure. Marty made about 1600 HP from a 406 ci engine. If I have the same cylinder pressure in a 505 ci or 535 ci engine engine how much more HP will I be making?
Stan
Pontiac Pump Gas List
  #45
Old 02-15-2022, 10:40 AM
GTO George
Where did you hear that they are gas filled?
  #46
Old 02-15-2022, 10:52 AM
GTOGEORGE's Avatar
I’m not sure maybe it was another ring, I’ll have to do some research, thanks for catching that.
GTO George
  #47
Old 02-15-2022, 11:28 AM
GTOGEORGE's Avatar
Stan
You are Correct! I pretty sure you are stating the obvious!
GTO George
  #48
Old 02-15-2022, 11:36 AM
GTOGEORGE's Avatar
So where did you get your rings?
GTO George
  #49
Old 02-15-2022, 11:52 AM
Must not read my posts George, I previously posted in the last day or so that the rings are available from Bob and Frank.
If you don't know who Bob and Frank are they are the All Pontiac Guys.
  #50
Old 02-15-2022, 11:53 AM
GTOGEORGE's Avatar
GTO George
There are other rings out there that are gas filled I guess Marty’s rings are not!
GTO George
  #51
Old 02-15-2022, 12:05 PM
GTO George
All Pontiac
  #52
Old 02-15-2022, 12:06 PM
GTOGEORGE's Avatar
All Pontiac
OK…..just curious!
GTO George
  #53
Old 02-15-2022, 12:12 PM
GTOGEORGE's Avatar
All Pontiac
Have you machined you block/heads if not maybe you would want to look into the rings/hoops the Steve Morris has…..just for the heck of it!
GTO George
  #54
Old 02-15-2022, 12:14 PM
GTO George
Steve isnt the only one that has the hoops...Just for conversation sake, where did you get your HP capability numbers of the Marty rings?
  #55
Old 02-15-2022, 12:24 PM
GTOGEORGE's Avatar
Just a guess....so don't worry. If I've read correctly they came out in the 90's that's 30 years ago......HP numbers have changed a lot since then......speacialy for Pontiacs. Its like anything else.........things change! Just for sh_ts and giggles........who has used Martys rings.....besides Marty?
GTO George
  #56
Old 02-15-2022, 12:25 PM
GTOGEORGE's Avatar
Yes others are selling those rings.
I would use them but i would have to deck my block a lot to get rid of my current o-ring set up.....pain in the butt. My set up is sealing fine now that i switch to the ARP2000 head studs!
GTO George
  #57
Old 02-15-2022, 12:27 PM
GTO George
So you came to that conclusion over the fact that the rings came out in the mid 90s?
  #58
Old 02-15-2022, 12:30 PM
GTOGEORGE's Avatar
DONT split hairs.....I can't do that.......
If what I read is correct that's when Marty stared to mess with them.
GTO George
  #59
Old 02-15-2022, 12:33 PM
GTO George
I'm not splitting hairs at all...Just admit that you just threw a number out there, right off the top of your head.
  #60
Old 02-15-2022, 12:36 PM
George likes to argue, let it go Opeliac, and run your program.
