Industry Stuff new repro's, updates, other info.
Old 04-06-2022, 12:19 AM
Scott Thelander's Avatar
Default In-line tube blooper
Not many of us are using a 69 n up bolt thru side cover levers and a 68 n older reverse with stud n nut on our muncies….
Hmmmmmmmm
Old 04-06-2022, 07:20 AM
gto4evr gto4evr is offline
this is in reference to what?
and as a matter of fact, when I finally get around to it, that's exactly what I'll end up having. both my 69's have 68 M21's in them and I bought two sets of 69 side levers off ebay years back so I could get the correct back lock linkages set up in them and it looks like too much work to change the reverse lever along with the other two that just need the side cover popped off to replace.
Old 04-06-2022, 12:04 PM
ooops .... this link didnt show last nite
https://www.ebay.com/itm/18180781156....c100667.m2042
67 68 reverse lever with 69 70 1-2 3-4 levers
h,,,,mmmmmmmmmm they must be shipping the correct parts
just an incorrect picture ,,, or theres 29ish buyers bummed out
Old 04-06-2022, 01:10 PM
ah, I get it now, with the cutout on the plates. I guess I never even thought about the plate differences. I've got factory 69 shifters levers/rods/plates waiting to get swapped along with the shift dogs when I get my setups correct. ( I meant the shift dogs, not the levers in my first post) right now it's just got the 68 tranny and an "aftermarket" hurst competition in it with the back up light switch add on mod to get the back up lights on. I've got all the back lock stuff in a box waiting to switch it out (along with the custom pivot bolt I had to make because Ames/inline, etc is only selling the 70-72 version calling it 69-72 when there's a difference in that front pivot setup for actual 69 factory setups. the repops are modeled on the 70 versions so those pivot bolts are not interchangeable.
I'll bet those buyers have had to use the round file after complaining, or just swallowed it as par for the course with repop garbage.
Old 07-12-2024, 10:25 AM
Formula403 Formula403 is offline
Much of Inline Tube accuracy is a myth. From their listing of every product as NOS to their listing applications that are completely inaccurate and take minutes to confirm, ten years ago. They have some excellent parts, they have just as many that are not even usable.
The ads of incorrect parts is just like the sets of mirror gaskets for 70-81 Firebird or Camaro, with LH and RH gaskets, then pointing at the million prior sales like even one of them has been able to install what they purchased correctly.
The Following 3 Users Say Thank You to Formula403 For This Useful Post:
Old 07-12-2024, 02:15 PM
