Old 04-06-2022, 08:27 PM
Ramairnacho Ramairnacho is offline
Default Rear
Originally Posted by unruhjonny View Post
I was astonished when I saw what the rear cases were going for - I looked into it with hte idea of replacing my 902's original - but quickly changed my mind.
I bought an unstamped open face front case to basically make a backup or sit in replacement for my '902.
The bavk.finnwd diamond did cost , and it is a diamond finned. Do you know of the 69 version that has a mounting bolt at the 6 pack instead of 4 oclock.still works if you actually rotate the rear 90 degrees counter clock wise
Old 04-09-2022, 01:35 PM
68bird400HO's Avatar
The rear case needs to be clocked with the plug at 9 oclock (viewing from the back) to be in the correct place for the wiring harness.
Also, pulled the fan and pulley off my unrestored 902 (April date code) to check plating. I can see what looks like a lighter gold plating on the back of the pulley. The fan is cad. Pics below but hard to get the lighting to see the gold on the pulley. The last pic is the fan and pulley from a later 60s 10dn alt. Clearly cad on both. Same fan style as 902.
ID:	588327   Click image for larger version
ID:	588328   Click image for larger version
ID:	588329   Click image for larger version
Old 04-09-2022, 03:02 PM
interesting so the pully and fan are cad? i read pully only lol this ias confusion stuff. also read all zinc too! can anyone tell me correct pulley detain for a 904 with power steering and ac? i dont know the diameter or v groove depth.
thanks
Old 04-09-2022, 10:12 PM
thanks
I was pointing out that the late 60s pulleys looks silver cad but the pulley off my 902 looks possibly gold cad or zinc. The fans both look to be silver cad.
The Following User Says Thank You to 68bird400HO For This Useful Post:
Old 04-09-2022, 10:41 PM
Default Fan and pulley
What's the diameter and v groove of pulley? Is there any special.offset?
Old 04-10-2022, 12:28 AM
The pulley on my 902 is 2-3/4" in diameter.
Old 04-10-2022, 11:49 AM
thanks alot now i need to find a cad pullkey or get one plated. Thanks
Old 04-10-2022, 09:37 PM
racerboy's Avatar
racerboy racerboy is offline
Just to jump into the mix here since I’m in the hunt for a 902 alternator myself now. Had a great phone conversation with RamAirNacho earlier today. For a car with an 06C build date, what would be a reasonable alternator build date. I read on a Camaro forum that they use anything from 2-weeks before the build date to a couple of months back. Was Pontiac any tighter on these dates than the Chevy clowns? Lol. Just kidding.
Three times the sound peaks, falls back, peaks again. A throttling back to cruising speed, a dwindling grumble of thunder and...gone.
The frogs take up where they left off.
The Following User Says Thank You to racerboy For This Useful Post:
