Old 04-09-2022, 12:52 PM
ZeGermanHam's Avatar
Default Trunk drain plug orientation
Can someone please enlighten me on the correct orientation for the drain plugs in the trunk? Should the indentation of the plugs be upward or downward? I feel like I've seen it done both ways, but I'd like to know how they came from the factory. Thanks!
1998 BMW 328is (track rat)
Old 04-09-2022, 01:55 PM
rare4k's Avatar
rare4k rare4k is offline
The go up looks incorrect but that's the way they came
Sent from my moto z3 using Tapatalk
Old 04-09-2022, 02:05 PM
That was my hunch, thanks!
Old 04-14-2022, 07:07 PM
Barrier Blue's Avatar
Barrier Blue Barrier Blue is offline
Indentation downward.
When I'm paid, I always follow my job through...you know that.
http://www.youtube.com/watch?v=Al2b-...eature=related
Old 04-14-2022, 07:13 PM
Alright, so we have one vote for each way...
Old 04-14-2022, 07:55 PM
242177P's Avatar
242177P 242177P is offline
Indentation up. If you stop and think about it, there will be a low spot under the
carpet/trunk mat when installed the wrong way. Straightedge says assembly line
knew what they were doing.
Old 04-14-2022, 07:57 PM
This was my logic when I installed the plugs in the cabin of the car. There would be a low spot if you install them with the indentation downward. I'd have to assume the factory would have figured the same for the trunk.
Old 04-15-2022, 12:21 PM
squidtone's Avatar
squidtone squidtone is offline
Well, I looked at this thread and in trying to remember, I got confused too, so I looked at my old pictures of my 67 floor after I ripped it out...I took pix to document the tab that held the wire from the sending unit (I think the ground wire). This is in regards to the holes at the forward part of the trunk floor..
The holes at each side have inner edges that are flared DOWN. (note these pictures of the outside of the panel...on the ground...it's been removed from car) You can see in the picture that's zoomed out. The center hole was slightly flared UP. It's the picture zoomed in a bit where the tab is.
Pix attached are of an original floor....
So there's one data point for you!
GOOD LUCK!
Dave
ID:	588775   Click image for larger version
Dave
http://www.squidsfabshop.com/?
(updated January, 2013, Pypes exhaust installation)
Old 04-15-2022, 09:00 PM
400 4spd.'s Avatar
Indentation in the plug is always up, regardless of location.
Old 04-21-2022, 06:52 PM
gtobird's Avatar
gtobird gtobird is offline
Question
Well, surprise, surprise, surprise. I've read about this over the years and went on a scavenger hunt at the American Muscle Car boneyard in Vancouver Washington about 14 years ago (ballpark). I've seen both! I'm told the official correct postion (from what I've read) is the hump goes up, but..................... quite a few factory installers did what seemed more obvious and installed them hump down. So, you could have either, though supposedly hump up is correct.
Believe it or not............ yours to decide
68 Firebird Convertible
68 GTO Clone (Tempest) Wagon
