Old 05-21-2022, 08:32 AM
A little grinding on the corner of the main cap and I used a stock dipstick with my deepened Canton.
Name:	500windage tray1.JPG
ID:	591230   Click image for larger version
  #42
Old 06-04-2022, 06:57 AM
spectramitch's Avatar
spectramitch spectramitch is offline
Finally got it done! Everything came out awesome. Caps fit perfect, thrust is cut within .001 and the tapping went smooth with no vented water jackets.
ID:	592117   Click image for larger version
ID:	592118   Click image for larger version
ID:	592119   Click image for larger version
ID:	592120   Click image for larger version
The Following 2 Users Say Thank You to spectramitch For This Useful Post:
  #43
Old 06-04-2022, 09:36 AM
73 TRANSAM 73 TRANSAM is offline
You did an excellent job on your splayed 4 bolt cap conversion. The only thing I like better is to put a stud on the outer bolt as I feel that the stud is better on clamping load. Excellent work!!!
  #44
Old 06-04-2022, 11:30 AM
25stevem's Avatar
25stevem 25stevem is offline
Superb work!
I do stuff for reasons.
  #45
Old 06-05-2022, 01:40 AM
Dragncar Dragncar is online now
I just want to say, DIY ? That machine shop looks nicer than 95% of the shops that do splayed billet caps for a living.
Very nice, good luck with it.
  #46
Old 06-05-2022, 05:59 AM
Good for you! You didn't need any real help, just a nudge from the forum to get it done...
Nothing like taking on a task like that and succeeding... it will feel great knowing the muscle under your hood was done by you!
Job well done!
  #47
Old 06-07-2022, 07:09 AM
RUDOLFSSON's Avatar
RUDOLFSSON RUDOLFSSON is offline
Good job.. thanks for sharing your adventure
  #48
Old 07-05-2022, 03:24 PM
Well she is back in my hands and its time to start checking clearances. I am wondering what torque sequence is proper for the Splayed caps? Do I finish torque studs then do the splayed bolts? or incrementally both of them? The engine machinist specified 100ft/lbs on studs and 65ft/lbs and splayed.
ID:	593774   Click image for larger version
  #49
Old 07-05-2022, 07:48 PM
younggto younggto is offline
Correct, torque the main studs in steps to final torque, and then torque the splays in steps; typically mains in 3 steps and splays in 2. The main studs secure the crank and set bearing crush and the splays tie the block together. Grade 8 bolts for the splays; not nitpicking and should be fine but just curious.
  #50
Old 07-05-2022, 09:53 PM
I took mine down to 20 and then to full tq spec in one long pull.
  #51
Old 07-08-2022, 05:28 AM
Well some disappointing news, checking main bearing clearance with my Mitutoyo tools I am ending up with .0038-.0045 using King MB5511HP-STD. My Brand new Scat Forged crank measures 2.9991-2.9993. I measured my actual main bore diameters by taking the Dial bore gauge, zeroing on the main, and then moving my Mic around it back to zero. Main Housing Bore is 3.1892-3.1899
Factory Spec is to be 3.188-3.189 with preference on the small side?
Is this a redo align hone situation?
  #52
Old 07-08-2022, 10:20 AM
My 455 was set up that loose, Great oil pressure and been running forever.
  #53
Old 07-08-2022, 01:03 PM
Bearing Crush or Journal clearance?
does the 0.0038-0.0045 get divided by 2 for the Main journal Clearance?
  #54
Old 07-08-2022, 01:05 PM
Journal Clearance, not sure what you mean by divide by two?
  #55
Old 07-10-2022, 09:55 AM
HIS, I understand what you mean now that my clearances are twice the size they should be lol.
I cant believe this could be the reason for my excessive clearance...but the machine shop said use ARP thread lube for torquing. I didnt get the lube from summit yet so I just used oil for doing my bore checks. Is this ARP lube really going to tighten up my clearance?
The Following User Says Thank You to spectramitch For This Useful Post:
  #56
Old 07-10-2022, 10:33 AM
King makes a 0.001 tighter main bearing for 3" mains.
  #57
25stevem's Avatar
Your housing bore is too big by at least.001” it seems.
My FM bearing book calls for a minimum bearing clearance of .0006” to a max of .0036”.
  #58
Old 09-06-2022, 05:57 AM
I had my machine shop rework and drop the caps to tighten up my main bore housing to be on the small size of spec 3.1880. Now im getting clearances in the .0022 range. I am using King HP bearings and want to run a 30wt oil. Is the .0022 on the mains to tight for a street strip 3" main? Its a Scat forged 4.25 stroke, 12-1 compression SR cam.
  #59
Old 09-06-2022, 09:21 AM
mgarblik mgarblik is offline
By "drop the caps", I assume that means cutting the caps? After they were done doing that, did they line hone the housing bores to make them round again and remove any taper from cutting the caps? There is a little more to finishing this up than just cutting caps. Your installation work of the caps looks very nice, just make sure it is finished 100%. I don't like to run a block without line honing. I like to finish the housing bores on a 3" main block at 3.1883-3.1884. I like 80% of the bore diameter to gauge at +-.0001 of that dimension with some growth toward the parting line. I like all 5 mains +-.0001 in taper. If you have those dimensions, your King bearings will have around..0028"-.0032 oil clearance. Looking really nice so far.
  #60
Old 09-06-2022, 09:22 AM
As you know, Bearing crush is most important. Journal clearance can adjust for application.
I never really knew-for-sure what weight Oil is best for higp rpm racing. And assume it applies to Reliable Highway use. For me the Street oil weight considers the HFT cam needs.
My efforts concluded 10W-20 to 10W-30, while ECM (Langer) may have joked about oils south of 0W-20. I dunno, and want to know.
