Old 06-01-2022, 07:05 AM
Yellow Banana's Avatar
Yellow Banana Yellow Banana is offline
Thanks for the info guys. I think this may be the way I will go. Does the T350 fit ok in the Slim Jim tunnel?
Any experience with a lockup converter?
Old 06-01-2022, 09:21 PM
See my PM for more info.
Old 06-02-2022, 10:16 AM
pfilean's Avatar
pfilean pfilean is offline
Look close at the pictures I posted. There was a little tunnel working at the tail shaft to case joint. Not sure how necessary it was as it now looks like enough room. I have heard of some who on a 350 ground off the lug on the case just if front of the tail shaft to case join. I didn't and am not sure if it would be necessary. I don't seem to have any problem. Also, the accumulator. I didn't have any tunnel work there and it is tight but has not been a problem. If you are going to try to use a stock dip stick I expect you may need to make some clearance. Do a test fit first and see where the problem areas are.
I don't have a lock up converter but I think it is only a matter of running some wires.
Old 06-02-2022, 11:01 AM
PONTIAC LARRY's Avatar
PONTIAC LARRY PONTIAC LARRY is offline
you'll laugh at what I did on my 63 Catalina drag car 455 TH350.. instead of stock transmount and clearancing the floor I did no rear mount but did a 1.25 straight square tube crossmember across frame direct bolted in and drilled two half inch holes and used some 1" pvc cut about a inch long as spacers to rest on the tail housing where thhe mount bolt threads are and ran 2 SBC 7/16 shank head bolts with a shock rubber gromet on them as a washer thru the square tube bottom up into trans case so my crossmember is also the mounts. Has worked great so far 1.6 sec 60 ft times wheels up . Seems stronger to me against twist as the trans mounting mounts to cross member are much further apart now vs like a single stud like some.
63 Catalina coupe 467 cid budget drag car low 11's 1/4 , 7.0's 1/8th pump gas n/a
66 Star Chief Executive 59k mile 389
67 IH Scout project 2WD "Indian Scout"
69 Le Mans 2 dr HT 350 91k mile 15 sec 1/4
69 Firebird 400 Burgandy/Black
70 Olds Rallye 350 F85 4 speed 3.91's
70 Olds Cutlass Cruiser Red Wagon 350 108k miles 15 sec 1/4 12 sec w 455
74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8
2020 RAM 1500 SLT 4x4 5.7 A8 Hemi
2008 Saab 9-3 2.0T convertible
