Old 07-25-2022, 12:46 PM
pontiacpetey's Avatar
pontiacpetey pontiacpetey is offline
Default i want to get my ac running 72 lemans, need part sources and advice
I want to get my ac running, the shop told me i need a new compressor, poa valve and expansion valve. i don't know if its better to convert to the 134 or keep the r-12. Any good sources for parts? Do I need new hoses? The ac guy said it would be cheaper for to order the parts as he would have to mark them up and her would most likely buy them from the same sources. Oddly he didn't recommend replacing the dryer which i read is a must. Im a noob with this stuff and did a little searching but didnt find all the info i was looking for.
Thank you for any advice, pete
Many men go fishing all of their lives without knowing that it is not fish they are after. ~Henry David Thoreau
Old 07-28-2022, 07:17 AM
gpmodelj70 gpmodelj70 is offline
Stay with R12...pull a vacuum on it and see if it leaks...at a minimum replace the dryer.
Marriage is defined by GOD, not by popular culture!
Old 07-28-2022, 07:09 PM
Formulabruce's Avatar
Definitely change the dryer and suck it down. You can put a pressure switch in and make your R12 system cycle like a new car with correct pressure switch. Does compressor have oil, does it spin? Does clutch work?
" Long may we DRIVE !"
Old 08-01-2022, 03:03 PM
tjs72lemans tjs72lemans is offline
I replaced everything on my 72. I used Old Air a division of Classic Air. But, I didn't have a condenser, figured my compressor needed rebuilding, wasn't sure of condition of evaporator or poa valve or drier. Needed some brackets. My car was apart when I bought, so I had no history. I now have a functioning, cold blowing AC system that runs off about 5 hp rather than about 15 hp. It uses 134a. I also see that they rebuild compressors and poa valves if you go that way.
Old 08-02-2022, 12:13 PM
Did you use your stock evap case and inside controls? pic?
Old 08-02-2022, 04:33 PM
I did use my stock evap case and all inside controls. Nothing changed. The system was a direct bolt in. The only thing that looks different is the compressor and brackets for it. Very easy to install everything and I have NEVER messed with AC stuff before. I had it evacuated and charged at the local Chevy dealership and it was all good. Plus, it only cost $140. I was shocked.
ID:	595639   Click image for larger version
The Following User Says Thank You to tjs72lemans For This Useful Post:
Old 08-02-2022, 04:41 PM
indymanjoe's Avatar
Have a link? sounds like a great deal.
I am the Thread Killer!
