SOLD Parts The parts in here have already been sold. The topics will be kept for a few months for reference.
Old 08-10-2022, 12:38 PM
charlie66's Avatar
Default Koni adjustables front shocks
Brand new in box. Bought them for my 64 LeMans but never used them.
175.00 obo plus shipping.
ID:	596210   Click image for larger version
ID:	596211   Click image for larger version
My Half AN Injun.....
Old 08-10-2022, 08:09 PM
Brentco's Avatar
Brentco Brentco is offline
That’s what I run — they’re good shocks.
1976 Trans Am Buccaneer Red
468ci, 10.5:1 CR, 87 CC RPM CNC e-heads, HR 282/288, 230/236, 561/.573 lift, Johnson Lifters & HS 1.65 Rockers
The Following User Says Thank You to Brentco For This Useful Post:
Old 08-10-2022, 09:12 PM
Had them as original set in my 69 Bird. ADJ by collapsing and turning.
Old 08-11-2022, 01:55 PM
MidnightAuto's Avatar
MidnightAuto MidnightAuto is offline
So what does the adjustment do? Change ride height (without any modification to springs)? And if yes, that can adjustment be done while installed in the car?
Old 08-11-2022, 02:14 PM
charlie66's Avatar
No it does not change the ride height.
You compress the shock all the way and you'll get it area where it locks in and then you turn it and it makes it stiffer and stiffer as you turn it.
Old 08-11-2022, 02:18 PM
First in line.
Sent PM.
Old 08-11-2022, 04:48 PM
Tim john Tim john is offline
I run these in a 69 Firebird, excellent shocks.
Tim john---
Old 08-12-2022, 10:42 AM
ROCKETMAN269V's Avatar
ROCKETMAN269V ROCKETMAN269V is offline
These shocks are excellent for tuning your suspension for a level launch. We used them on the car in my avatar. By staggering the extension/compression adjustments, you can tailor how the four corners of your car react to the torque applied to the chassis when a vehicle hooks up and launches. They control the twist normally seen with stock suspension.
You do have to remove them to compress the piston to make changes; however, I fabricated a tool to do them on the car.
Old 08-16-2022, 07:49 PM
charlie66's Avatar
Sold.. Thanks b-man
