Old 08-18-2022, 11:59 PM
Fast 69's Avatar
Fast 69 Fast 69 is offline
Default Turbo timing curve
Curious what the turbo guys are running for timing under boost. Im running a 440” (4.185” bore x 4” stroke) with Edelbrock old style chamber heads. 10-1 compression with Butler spec’d solid roller. Blow thru on E85. What kind of initial timing and timing under boost is everyone running?
Old 08-19-2022, 07:33 AM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
505cid, 10.5:1 DCI RAV Heads, C16 fuel.
Name:	Raven AUG 2021 timing Map.jpg
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
The Following User Says Thank You to RAIV-Z For This Useful Post:
Old 08-19-2022, 11:14 AM
charlie66's Avatar
9:1 - Initial 6 degrees @ 22 psi 23 degrees . 30 psi 18 degrees . 35 psi 13 degrees. With the new Edelbrock head. The older design head was different you can use more timing..
My Half AN Injun.....
The Following User Says Thank You to charlie66 For This Useful Post:
Old 08-19-2022, 11:39 AM
Fast 69's Avatar
What fuel are you running Charlie? Did you mean 36 initial? That where I’m at but I’m pulling more timing right now to be safe. I’m at 18* at 18 psi and down to 14* at 25 psi. Plugs looks decent but I think I can add some timing.
Old 08-19-2022, 11:45 AM
turbo69bird's Avatar
I run 20 degrees under full boost at 17 psi currently.
I’m at 34 cruise and I get 17 mpg. W 160 lb hr injectors.
960 HP @ 11 psi, 9.70 at 146.
The Following User Says Thank You to turbo69bird For This Useful Post:
Old 08-19-2022, 01:42 PM
Fast 69's Avatar
What your combo? What fuel are you running?
Old 08-19-2022, 01:51 PM
Fast 69's Avatar
What plugs are you guys running? I’m using NGK R5671A-10.
Old 08-19-2022, 03:13 PM
charlie66's Avatar
When i said 6 initial i meant at idle . Im at 34 degrees cruising . I use E85 fuel.
If you ask me you're timing settings are really conservative with the old style E head.
With the older version head i was at 23 degrees @35 psi . But dont listen to me , work up into it by reading your plugs. Im sure you already know this but i just have to say it.lol
At 25 psi i was at 24-25 degree ( old head )..
Old 08-19-2022, 03:15 PM
charlie66's Avatar
I use 8 heat range plug. I have used #7's in the past .. Only on E85 fuel ...
Old 08-19-2022, 03:32 PM
charlie66's Avatar
Here's one of my center plugs also another picture of it with the threads cut off so you can see the ring . it's just under an eighth inch in width ring around the base.
ID:	596786   Click image for larger version
Old 08-20-2022, 10:27 PM
70 bird's Avatar
70 bird 70 bird is offline
Locked at 32 with the btm pulling back to 22 at 15psi. 8.7-1 compression with 93 pump gas. I also add meth injection starting at 8psi.
The Following User Says Thank You to 70 bird For This Useful Post:
