Old 10-09-2022, 08:15 PM
tom s tom s is offline
Is it just me or we are making a mountain out of Mole hill on a street pontiac?I can give a rats a-s about 5-10 HP!JMHO,Tom
The Following 3 Users Say Thank You to tom s For This Useful Post:
  #42
Old 10-09-2022, 11:10 PM
slowbird's Avatar
slowbird slowbird is offline
Some of us care about 5-10 hp. If I can find 10 places to find 10hp I'll be happy
The Following User Says Thank You to slowbird For This Useful Post:
  #43
Old 10-10-2022, 07:28 AM
Interesting discussion. I'm always looking for 5-10 HP in our street cars but I've never went after it through the alternator. Always figured there wasn't much there.
I have played with fans however.
https://youtu.be/XqEydRRRwqE
  #44
Old 10-10-2022, 10:22 AM
Steve C. Steve C. is offline
A set up using electric fans only for cooling. I've seen it stated by some who track tested with the fans on and with them off, results were no measurable difference in ET & MPH.
Old information here:
  #45
Old 10-10-2022, 12:59 PM
slowbird's Avatar
I always shut my fans off right before staging, but I didn't run an alternator. I wanted all battery power going to ignore and fuel pump.
  #46
Old 10-10-2022, 01:11 PM
We just race our street cars right off the street with working clutch fans and alternators, half the time don't even open the hood. Easy Peasy
Shucks last time at the track dad had a starter issue and just left the darn thing running in the staging lanes
  #47
Old 10-10-2022, 01:47 PM
slowbird's Avatar
That's what we do with our street cars also. But always looking for more, lol
  #48
Old 10-10-2022, 02:09 PM
Agree, we're hotrodders, that's what we do
  #49
Old 10-10-2022, 04:30 PM
NeighborsComplaint's Avatar
It was once popular to run a tiny import car alternator both for weight and parasitic drag reduction.
Triple Black 1971 GTO
  #50
Old 10-10-2022, 04:56 PM
Most all of the GM solid lifter cars had underdrive deep groove alternator pulleys to go along with the rest of the deep groove pulleys. Doesn't spin the alternator as fast as the typical conventional pulley.
My Z still has it's original setup on the factory 37 amp alternator.
I had another one of those alternator pulleys I ran on the Chevelle for years. Same 37 amp alternator. Doubt it does a darn thing for HP but it sure helps keep the belt on when you zing it.
I later switched to a 55 amp alternator, same pulley. I later switched back to the stock tiny steel pulley to up the juice during idle conditions.
Maybe I lost a 1/2hp
  #51
Old 10-10-2022, 05:52 PM
mchell's Avatar
mchell mchell is offline
I’ve played with cutting out the alternator field via a switch. Yes, it did yield a slight improvement at the track. Mine was .02-.03 reduction in et best I could tell…
Problem I had was my fuel pump would slow down a bit with the reduced voltage. At times this would prove detrimental. IF the fuel pump kept me in fuel, cutting the field reduced my et slightly.
Removing the power steering pump belt generally gives me an easy .05 or more…. Both mods get me close to a .10 in et reduction as I recall.
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile
  #52
Old 10-10-2022, 08:16 PM
Half-Inch Stud Half-Inch Stud is online now
In reality, the Alternator is drawing < 1 hp at cruise. 1/4 mile acceleration would be a few HP lost.
Nobody 1/4 miles with a dea battery, Hi-beams, and a 30 Amp electric fan all running.
My electric fan only goes on when i turn it on: really long traffic lights, jams, and after the 1/4 mile run.
  #53
Old 10-12-2022, 11:37 AM
Stumann Stumann is offline
Originally Posted by Dragncar View Post
Well, 4-5 hp is a lot better than 22 hp required for both water pump and fan.
Wondering what the difference would be with a 36 amp alternator going to a 100 amp alternator.
I don't think it would matter what the maximum amps of an alternator is, what robs horsepower is the draw on the alternator at any given time. If you have an electric fan drawing 15 amps, it's still only a 15 amp draw regardless of the max output of the alternator.
  #54
Old 10-12-2022, 03:26 PM
AG's Avatar
AG AG is offline
I'm pulling 65 amps down the track with an electric fan, water pump, fuel pump and MSD box. Most of it is the Mark VII fan pulling 44 amps.
  #55
Old 10-12-2022, 03:41 PM
Agree the Mark VII uses a bunch of amps to drive that electric fan.
At one time that was a very good fan for a engine pulling a trailer and race car.
Depends on what your application is, simple really.
  #56
Old 10-12-2022, 06:53 PM
Craaap. My elec fan is in the 15-20 A catagory, a GM upullit deal. Sold my identical spare.
May be putting the flex fan back on some day.
  #57
Old 10-13-2022, 12:55 PM
Formulabruce's Avatar
There MUST be some merit to the question. My Wifes 2020 Nissan Daily driver has a small, but powerful alternator ( around 100a)
This small alternator has a CLUTCH inside it, similar to a clutch on a AC pump... You cant see it. I would have never known except the belt would flutter
and make noise, so the whole $500.00 alternator got swapped under warranty.
I am betting Other brands have gone to this for fuel economy reasons... so it IS worth discussing..
There ARE reasons you will NEVER see a alternator on a EV....
" Long may we DRIVE !"
  #58
Old 10-13-2022, 12:57 PM
Factory clutch fan has been found to have the least drag and least affect on horsepower. If that enginemasters video IS the full edition, it shows this at the end, much to the dismay of Jeggs, Summit, etc...
The Final test on the engine masters video WAS the factory clutch fan and shroud. This was edited OUT of the video. Why? because it used the LEAST power, and because it really puts a damper on aftermarket "sponsors" of motor trend.
Its sad this classic info is missing, it was a huge shocker to them...
  #59
Old 10-13-2022, 01:18 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Interesting thread. My guess is 95% of street cars would find more power in a better camshaft design than the least efficient designed alternator would take away power wise.
Go fast, see Elvis!
  #60
Old 10-13-2022, 01:25 PM
Yep, long before there was engine masters I recall a certain magazine that did a fan shootout article. May have been Car Craft. I've even posted that info with a link to the actual article on this forum in the past.
The only thing that beat the clutch fan setup, was no engine driven fan at all.
