Old 10-14-2022, 09:56 PM
chuckies76ta's Avatar
Default Wix oil filters
Hi: Today I cut open my Wix oil filter # 51258. I run Amsoil 10w-40. This filter is a very well made filter in my opinion. There has been lots of talk about oil filters lately. Just posting for information only. Everything in the filter is metal except for the rubber check valve.
ID:	600450   Click image for larger version
ID:	600451   Click image for larger version
ID:	600452   Click image for larger version
ID:	600453   Click image for larger version
950 Quickfuel.
Old 10-14-2022, 09:58 PM
Couple more pic.
ID:	600455   Click image for larger version
Name:	oil filter.jpg
950 Quickfuel.
Old 10-14-2022, 10:05 PM
1968GTO421's Avatar
I too use Wix and have cut them open and found them to be like yours, well made (JMHO). I've used them on our daily drivers for years, no problem. Of course, things can always change with time.
GTOAA--https://www.gtoaa.org/
The Following User Says Thank You to 1968GTO421 For This Useful Post:
Old 10-14-2022, 10:14 PM
shaker455's Avatar
X3 on WIX filters
That's what I use, that and Valvoline VR-1 20/50 Racing oil with ZINC in 71' Trans Am
My 67' GP I do use Chevron Dello 15/40 with some Lucas ZINC break -in oil, original engine & miles, never been rebuilt.
The Following User Says Thank You to shaker455 For This Useful Post:
Old 10-14-2022, 10:29 PM
redbird68's Avatar
redbird68 redbird68 is offline
Good to see. Thanks.
I've been using the same for years on my pontiacs. VR-1 10/30 oil now, different stuff in the past.
Never had an issue.
birds, goats and a few outliers
The Following User Says Thank You to redbird68 For This Useful Post:
Old 10-14-2022, 11:07 PM
Sirrotica's Avatar
FWIW, one of the You Tubers cut open a WIX, and a NAPA platinum recently, and found the NAPA was different that the WIX, which until recently they were the same.
Since WIX was bought out by Mann and Hummel, a German firm, The top WIX line has had a few cost cutting measures implemented. The NAPA filter was also made by Mann and Hummel, but it was just a little better than the WIX was. Evidently NAPA speced their filter just a bit higher. The WIX was still plenty adequate, just a little less filter media in the can.
Here's the video link: https://www.youtube.com/watch?v=wP8f...ipCityWrencher
It's titled "WIX, what happened?
NAPA Platinum $14.49, NAPA online
WIX XP $10.99, Summit
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
The Following 2 Users Say Thank You to Sirrotica For This Useful Post:
