Old 10-24-2022, 07:48 PM
grandville455's Avatar
They come out the top, pressing outta the banjo. Here’s a friends home made one for pressing out and back in
Darby
M/T 275/60 ET SS Drag Radial
  #82
Old 10-24-2022, 11:35 PM
73 TRANSAM 73 TRANSAM is offline
I removed my booster on my 1050 dominator by screwing a screw on that banjo from the metering block side and pulling the screw with a vise grip. Then the booster just slides out from the top. Then just reverse the step for installation. I used a special grease that came with my kit. Not sure what is it, looks like a very thin red lube. Good luck.
  #83
Old 10-25-2022, 03:11 AM
Dragncar Dragncar is offline
Charlie, is this a 3 circuit carb or 2 circuit ?
  #84
Old 10-25-2022, 09:40 AM
Very common to do it that way and at one time you could buy the booster "retention" inserts, if you screwed on up on removal.
  #85
Old 10-25-2022, 11:14 AM
charlie66's Avatar
So i got the insert out. What hole size are your 12 holes? Mine are .056.
I did the area on .182 and the .056 . then x that by 12 and the 12 holes have .003540574184 more area then the .182 in the booster . Im not sure if they should be drilled being there's already more area . Anyone know the answer to this ?
My Half AN Injun.....
  #86
Old 10-25-2022, 11:16 AM
charlie66's Avatar
Two ......
  #87
charlie66's Avatar
Im not trying to take mine out ..
  #88
Old 10-25-2022, 12:13 PM
Sounds like u put a screw into the booster pin and removed the banjo with booster still inside, I'm talking about just removing the booster itself from the banjo, leaving the banjo and booster pin installed in main body, done it many times! I suspect charlie is still using gas sized holes in his 12 hole booster's and that's why its not entirely happy, I would enlarge them to .059
Darby
  #89
Old 10-25-2022, 12:18 PM
Simple yet effective!
ID:	601091   Click image for larger version
Darby
  #90
Old 10-25-2022, 01:34 PM
Roughly the alcohol setup needs 40% more area to flow enough fuel compared to gasoline.
  #91
Old 10-25-2022, 03:06 PM
I would open up the booster holes, and open up slot restrictor to .075 if it were mine and send it
Darby
  #92
Old 10-25-2022, 03:24 PM
charlie66's Avatar
So I drilled the 0.56 to .075 and then I drilled out the booster from 182 to 192.
  #93
Old 10-25-2022, 03:27 PM
charlie66's Avatar
I found out that 2 of the booster are loose . Anyone know of a tool they make to tighten them up?
  #94
Old 10-25-2022, 03:29 PM
charlie66's Avatar
are you talking about straight alcohol or e85? I went 30 percent ...
  #95
Old 10-25-2022, 03:42 PM
The Terminology here needs to be clarified lol, so the above is your boosters, and u drilled the holes from 0.56 to .075? what did u drill out to .192? what is loose? The banjos that boosters press into?
Darby
  #96
Old 10-25-2022, 03:49 PM
The red arrow is transfer slot restrictors n blue is your booster pins
Darby
  #97
Old 10-25-2022, 04:03 PM
charlie66's Avatar
The .056 to .075 is the 12 holes in the red insert .
The booster was drilled from .182 to .192 which your saying is the banjo.
My transfer slots are .098..
  #98
Old 10-25-2022, 04:08 PM
charlie66's Avatar
The booster/ banjo was loose. I never messed with a 4500 booster before . so im learning ive done many 4150's in the past so its different for sure ..
But i got the pin out and loc-tighted it back in . It seems ok but im going to get some new ones .
  #99
Old 10-25-2022, 04:28 PM
Blue arrow is the banjo , it’s what the booster presses into
Darby
  #100
Old 10-25-2022, 06:01 PM
charlie66's Avatar
yes i understand now . That was drilled to .192
