Old 11-22-2022, 04:00 PM
er455 er455 is offline
Default Turbo inlet ideas
Anybody got an idea on how to have my intake air hose closer to the turbo inlet so I can fit a bigger radiator in front of the inlet tube ?
Old 11-23-2022, 05:03 PM
Mo's Avatar
Mo Mo is offline
I keep looking but I cant see a way to make that happen based on the picture you provided.
Systems under stress fail catastrophically
Old 11-23-2022, 05:54 PM
X2
Outside of a complete Turbo Remounting closer to the right hand frame rail
and the turbo mount located there.
Old 11-23-2022, 06:50 PM
73 TRANSAM 73 TRANSAM is offline
How big is ur radiator?
Old 11-23-2022, 10:28 PM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
Agree with comments above, move the turbo.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
Old 11-24-2022, 09:26 AM
firechicken's Avatar
firechicken firechicken is offline
Can you offset the radiator to the other side?
Old 11-24-2022, 10:36 AM
chuckies76ta's Avatar
My son being the great welder he is, would take the radiator and remove a chunk out of it and Aluminum weld it back up. He would then make a beautiful 90 degree elbow out of that nice aluminum used for turbo pipe. He's a fabricator..Just saying.
950 Quickfuel.
