SOLD Parts The parts in here have already been sold. The topics will be kept for a few months for reference.
Old 11-30-2022, 11:18 PM
Bob Eiler's Avatar
Bob Eiler Bob Eiler is online now
Default SK version of Doug Nash tunnel ram
Has been adapted to side way mounted carbs (4150) using 1/2 in phenolic spacers. The plenum has been milled 1/2 in for hood clearance. Epoxy was added to the out side of runners for reinforcement in case of breaking through the runners which happened to two runners which was the size of a dime and a quarter. .Epoxy was also added a runner opening for gasket matching.
$500 shipped to lower 48
ID:	602805   Click image for larger version
ID:	602806   Click image for larger version
ID:	602807   Click image for larger version
ID:	602808   Click image for larger version
There is no such thing as too much cam, just not enough engine.
1966 GTO - 11.31@119 (3478 lbs) in 1979
1967 Firebird - 9.73@138 (2940 lbs) in 1986
400 cu in / 295-298 cfm RAIV / Lunati Cam 278/283 - .704 lift/5.13 gears
Old 12-01-2022, 02:33 PM
jspeed's Avatar
jspeed jspeed is offline
Default SK ram
Interested,.. What size ports are they opened up too, what intake gasket did you use.
What heads were you using.
How fast did you go with this intake , the port work looks extensive..
Thanks,..
Old 12-02-2022, 05:30 AM
Bob Eiler's Avatar
Sorry for the slow reply. The intake may be sold. I'll know by tomorrow. If not I'll give a better reply. Fwiw all Doug Nash intake ports are RAIV size.
Bob
Old 12-03-2022, 02:46 AM
Bob Eiler's Avatar
Default SK intake
Sold, thanks PY
