Old 01-04-2023, 03:10 PM
Formulabruce's Avatar
455 HO stock Cr. 3.42 rear, .67 OD. ( Stage 3 th2004R)
16 mpg on highway.
" Long may we DRIVE !"
Old 01-04-2023, 03:49 PM
Charlie Brengun's Avatar
Charlie Brengun Charlie Brengun is offline
SBC 350 Th350 3.08 posi in a 1977 camaro and i liked it so much i want a Pontiac 2nd gen these days, with t tops and the 455 from my GTO.
1968 - Pontiac GTO
Old 01-04-2023, 05:34 PM
current "new" car is the bestest yet -> 455/400 slush 3.08 posi
Old 01-04-2023, 07:21 PM
Default 2nd the 455 T400 308s
Decent from light to light and exceptional on the freeway.
Old 01-04-2023, 08:26 PM
DavesGTO's Avatar
DavesGTO DavesGTO is offline
Ram air iii, m-21 3:90 for me
Old 01-04-2023, 08:28 PM
6T5 Cat's Avatar
6T5 Cat 6T5 Cat is offline
1956 Chevy, one-fifty 2 door utility sedan with a Bill Jenkins prepared 1963 dual quad 425 HP 409, wide ratio Muncie and 411 posi.
[SIGPIC][/SIGPIC
Old 01-04-2023, 08:54 PM
PDC PDC is offline
I’m really loving the ‘Close Ratio’ T-56 (2.66, 1.78, 1.30, 1:1, .80, .63) with 3.73s out back. Not a dead spot in any gear.
Loved my TKO-600 car, but the 1-2-3 drop from 2.87 to 1.89 to 1.28 seemed a touch wide, and I never made peace with the 1:1 - .64 OD drop. Seemed like the car was either spinning higher than I wanted in 4th or felt a little soft in 5th anywhere between 65 and 75 mph.
Old 01-04-2023, 09:33 PM
besserspat besserspat is offline
I have an all original '99 Formula WS6 (supposedly the rarest Formula's ever made) with the T56 and 3.42s and its a real pleasure to drive, the bad part is I have to keep it low mileage lol...
Another of my cars thats a fun to drive is stock 1992 Corvette with a 700r4 and 2.59 gears, that this is surprisingly comfy , literally sips gas and with a removable targa top and its 20 gal fuel tank this thing is a perfect road trip car.... Actually did one around the 45 states and all 10 canadian provinces in it in 2014...yeah I got pulled over numerous times and got lucky numerous times
The Following 2 Users Say Thank You to besserspat For This Useful Post:
Old 01-04-2023, 11:51 PM
77 TRASHCAN's Avatar
When my 77TA was still in its prime( before the number7 exhaust lobe started going down...). It was a fun car to drive. The 7.6:1 400 was nothing like its predecessors. But the Pontiac engineers gave the tune. Either 16 or 18 degrees initial advance, and R45TSX plugs. Gapped at .060
The 400/Th350 with the 2.41 rear gear could get 20 MPG, on a good day, 22.
I have parts for more than one displacement build. I may resurrect a stock (BUT slightly massaged) 400, for at least a while.
Shut it off
Shut it off
The Following 2 Users Say Thank You to 77 TRASHCAN For This Useful Post:
Old 01-04-2023, 11:56 PM
blueghoast's Avatar
One of mine is a 64-Tempest-400 with a little cam(bought that way)
12-bolt posi 3:31 gear saginaw 4-speed with a 3:50 first gear works
great and pretty fast two. My 64-olds F-85 a while a go had a low comp
400 and a 350 turbo and a 275 shot of n20 and 4:33 gear. On motor
went 13:04 at 104 mph on the button it went 11:37 at 120 mph, That was
A blast back then. and mt 62-Tempest with a allum rod allum headed
Wenzler tunnel ram and two 750's 3:73 gear 350 turbo trans 7:22 lift
cam on a 113 lsa 10:45@128 mph drow that in Drag 3;73 Week and theres
Still more. I'll post up another build I'm getting ready to do 57 ponco wagon.
GT
Old 01-05-2023, 09:22 AM
@77Trashcan, try gap the plugs at .045", install a low resistance < 10 Ohm Rotor Button, the MPG and uphill TQ improve moreso.
Old 01-05-2023, 10:45 AM
carbking's Avatar
carbking carbking is offline
In a Pontiac:
3.23 rear, ST-10 with 3.42 low
Built before 5-speeds became common.
In a non-Pontiac:
5.13 rear, 2.96 low gear 5-speed overdrive (5th 0.85)
The 5.13 cut down on top speed, but 135 would get you a ticket almost anywhere
Jon
Old 01-05-2023, 10:58 AM
Mr Anonymous's Avatar
Mr Anonymous Mr Anonymous is online now
Non Pontiac - and it really hurts to say this. Mid 90s Ford Explorer with 5.0, some sort of AOD, and couldnt tell you what gear. That drivetrain seemed like it could read your mind. Always in the right gear, always responsive. Until it got completely destroyed in a black ice incident.
Pontiac - dad's 53 studebaker with 400/th400 and 3.00 gear. Always a joy to drive until it gets hot. Those Studes have a tiny radiator, and retrofitting something else is truly an ordeal if you saw how the frontend went together.
Clutch Guys Matter
53 Studebaker, 400 pontiac
1964 F-85 Home of the 700hp small-block Olds
**Still wanting a 64 Bonneville or Catalina**
Old 01-05-2023, 11:18 AM
track73 track73 is offline
I did a poor mans OD. My .030 over 455 with 96 heads and 041 cam with Rhodes lifters and 1,65 rockers has a cast iron T-10 with 3.43 first gear and a 2.73 rear. It acts like a 3 speed with overdrive. The engine has enough low end torque that can overcome any situation on the city streets with great highway manners.
1979 Trans Am WS-6 .030 455 zero decked
flat pistons
96 heads with SS valves
041 cam with Rhoads lifters 1.65 rockers
RPM rods
800 Cliffs Q Jet on Holley Street Dominator
ST-10 4 speed (3.42 first)
w 2.73 rear gear
__________________________________________________ _______________________________
469th TFS Korat Thailand 1968-69 F-4E Muzzle 2
Old 01-05-2023, 12:39 PM
racegto65's Avatar
racegto65 racegto65 is offline
My first car in high school. 1960 Ventura,389 tri-power,4 speed. 4.10 gear.
It's the on that got me addicted.
Old 01-05-2023, 01:36 PM
Nash 5 speed trans, 2.75 rear gear, 9" Strange Center section and Moser Axles.
Final drive on the Nash (5th gear) is 1 to 1.
The Following 2 Users Say Thank You to Tom Vaught For This Useful Post:
Old 01-05-2023, 03:06 PM
Its interesting how much we liked somewhat milder set up with numerically low rear gears... proof that you dont need tremendous amounts of power in a car to be really enjoyable.
Peter
  #38
Old 01-05-2023, 06:42 PM
The Champ's Avatar
My current set up in my '64 GTO is the one I like the best.
Originally, I drove it with the stock 389, M20 and 3.23 open rear and 26.5 - 27" tires. Next I swapped in a 3.36 posi, which was eventually replaced with a 12 bolt 3.42 posi.
After building a 462 and driving it with the 3.42's, I decided that I wanted less rear gear with the bigger motor. Swapped the 3.42's for 3.08's.
This combo is the one I like the best as I do spend time on the Interstates going to shows (I go 4 hours one way every year). At some time in the future, I may consider a TKX with the wide ratio - 3.27 first gear and a .72 overdrive. This would help me out at the stop lights with the 3.27 first gear and on the Interstate with 2000 RPM at 70 MPH with the overdrive.
The Following User Says Thank You to The Champ For This Useful Post:
  #39
Old 01-06-2023, 07:35 AM
Cliff R's Avatar
Cliff R Cliff R is offline
1967 Impala SS.
327, 700-R4, 3.31 12 bolt diff. I did a complete restoration on the car and built the little 327 with super tight squish, factory cam and high compression. It EASILY managed pump gas w/o any issues anyplace and made great power for the CID.
This helped produce a PERFECT combination in every area. With 3.31 rear gears and 3.07 first gear of the 700-R4 plus a custom built Precision Industries converter it was super-quick off the line and would knock down around 18mpgs around town and mid 20's on the highway running around 70-75 mph.
It was a blast to drive and one of the cars that I sold over the years that I really miss.........
The Following 2 Users Say Thank You to Cliff R For This Useful Post:
  #40
Old 01-06-2023, 09:42 AM
1967 Impala SS.
Now there's a name I haven't heard in a long time. I used to run one of their Vigilante converters in one of my LS powered cars. Awesome converters.
https://youtu.be/XqEydRRRwqE
