Old 01-19-2023, 09:40 PM
Could also be high carbon build up from the dual quads. A bit of Dextron down the throats while the neighbors are sound asleep might clear it out.
Old 01-19-2023, 09:44 PM
Also the cc’s of the adapter (as compared to the installed spark plug) can add a subtract a few tenths from the ratio.
Old 01-19-2023, 09:57 PM
SD455DJ SD455DJ is offline
We're going to run cold distilled water down its yap after its good and warmed up to knock the carbon off the pistons and chambers. The steam is a bit more neighbor friendly, lol.
Dennis
  #124
Old 01-19-2023, 09:59 PM
Yep, that's already accounted for in the process.
Dennis
  #125
Old 01-19-2023, 11:48 PM
Douglas Willinger's Avatar
Douglas Willinger Douglas Willinger is offline
How many 350 HO 4 door hardtops for 1969?
1970 Lucerne Blue Firebird Trans Am, deluxe blue interior. Original Ram Air III, M-21, 3.73. Being built as a 4" stroke "434" with SR 614 Ram Air IV heads
1972+ Lucerne Blue 4-door hardtop "what if" T-41 Le Mans Sport GT/Grand Am concepts. Equipped with future 3" journal "455 HO"/"what if" prototype "SD 455".
What if GM had continued production of the 1970-72 GM A body somewhere in the southern hemisphere?
  #126
Old 01-19-2023, 11:53 PM
Doug, only 30 - 4 door hardtops with all transmissions with the 350HO.
Dennis
  #127
Old 01-20-2023, 10:18 AM
Doug, here is the total 350HO production for '69 A-bodies (courtesy of Fred S. and Diego R.):
Tempest 2-door coupe: 85
Tempest 4-door sedan: 10
Custom S 2-door coupe: 87
Custom S 2-door hardtop: 597
Custom S 4-door hardtop: 30
Custom S 2-door ragtop: 45
Custom S 4-door sedan: 55
LeMans 2-door coupe: 117
LeMans 2-door hardtop: 2,687
LeMans 4-door hardtop: 254
LeMans 2-door ragtop: 271
Total: 4,238 A-Bodies w/350HO
Dennis
  #128
Old 01-20-2023, 10:56 AM
KSZR KSZR is offline
Probably not your style, but would look good with some Rally IIs on it!
  #129
Old 01-20-2023, 11:34 AM
Shiny Shiny is offline
FYI there is an NOS AC fuel pump on eBay right now.
Your original pump is probably fine !! Don't fix it if it's not broken ??
Link to eBay Pump
  #130
Old 01-20-2023, 03:37 PM
Oh, I like to mix it up a bit...
Dennis
ID:	605613   Click image for larger version
ID:	605615   Click image for larger version
  #131
Old 01-20-2023, 03:39 PM
Wow.
I haven’t ever seen such sharp 4-doors before, those cars are stunning lookers!
  #132
Old 01-20-2023, 03:53 PM
Wow.
Thanks Bart! Just don't get too close as these are truly 50 footers at 50 mph! These pictures do them justice I must say, but they are fun to drive!
Dennis
  #133
Old 01-20-2023, 07:10 PM
These are my go-to wheel covers for 69-70, love that "poor man's" Rally wheel look. This car was built with them but I'm putting a set on my LeMans Safari wagon too.
They aren't valuable but they are a bear to find, they just weren't installed on many cars. Unlike the six spoke deluxe wheel covers they cover the whole wheel (the deluxe leave the last half inch of the rim visible, giving the look of 13" wheels).
Old 01-20-2023, 09:02 PM
North, Those 5-spoke optional wheel covers look great compared to the "deluxe" pie pans. I now have 3 A-bodies that came with those ugly wheel covers that are in an ever-growing stack in the garage.
Dennis
  #135
Old 01-21-2023, 01:23 PM
Some really nice looking 4-doors there!
The Following User Says Thank You to will slow gto For This Useful Post:
  #136
Old 01-22-2023, 03:52 PM
The Kraco 8-Track tape player works (it only has the factory dash speaker - no rears, so not very hi-def)! John Denver never sounded so tinny.
Dennis
Name:	Kraco 8-Track Player 2.jpg
  #137
Old 01-22-2023, 07:15 PM
Kraco made mono and stereo 8 tracks. If you used the stereo version but didn’t hook up a second speaker to the other output you’d burn out the diodes within an hour. Of course if you didn’t have a speaker there you’d never know you burned them out.
My executive 4 door sedan had the same 8 track, the original owner installed it in 69. I don’t like the look of aftermarket stuff so I removed it but to honor the 8-track history I added a factory 8 track to replace it.
Old 01-22-2023, 10:04 PM
North, I never knew that about 8-Track players available in mono or stereo...learn something new every day. BTW, your Lemans Hdtp is flat out sweet!
Dennis
  #139
Old 01-22-2023, 10:38 PM
Same with stereo radios back then, they needed the 10 ohms of resistance on both the front and rear tracks to prevent the diodes from burning out.
GM never offered a mono 8 track but a lot of the aftermarket portables were mono along with some aftermarket car ones. The problem with the mono units is that you were only listening to half the song, depending on the song you might or might not notice it much.
That LeMans 4dr hardtop is a sweetie, got it from the original owner in Eugene Oregon about 5-6 years ago. About 69k miles and the 100% original interior is like new. Never had any rust or hits but it has a cheap repaint from the 80’s. Looks better in photos. Option wise it’s a bit on the high end of typical for the era with Cordova top, PS, PDB, 350 2bbl, TH400, AC, FM radio, reverb, clock, remote mirror, deluxe belts etc.
That car has given me respect for the run of the mill cars of the time. Despite being a regular fuel 2bbl engine and 2.56 gears it’s a joy to drive. Effortless around town acceleration and throttle response. Honestly it’s probably more responsive up to about 3,000 rpm than a Qjet equipped engine with the same gears. The only way it lets you down compared to a high perf engine is high speed acceleration or passing uphill on a mountain road or something. Ride is soft yet stable, just a very pleasant driving car.
Old 01-22-2023, 10:41 PM
77 TRASHCAN's Avatar
Rally 2'S looking good in the Michigan neighborhood!!!
Jeff
Shut it off
Shut it off
