Old 02-13-2023, 02:03 AM
wbnapier wbnapier is offline
Default 65 vs 66 Tri-Power
Questions,
Are they interchangeable?
I think the center carb flange is larger, is that true? Is there an adapter plate if running a '65 smaller center carb?
I have a '65 GTO, and I want to get a new tri-power intake and port the intake runners to match the #48 heads and intake gaskets (Fel Pro 1233), which are RAIV size.
I want to do it on a new one, so I don't have any down time on my car.
Thanks,
Brent
1965 Pontiac GTO
455/469 w/ #48 Heads, '65 Tri-Power
9.25:1 CR
Stump Puller Cam
Muncie M22W 1st-2.56 2nd-1.75 3rd-1.37 4th-1.00
3.55 Rear Differential
Front: 225/60R15 Height: 25.6"
Rear: 275/60R15 Height: 28"
Old 02-13-2023, 02:05 AM
https://forums.maxperformanceinc.com...d.php?t=786314
Tri-Power intake identification.
Yes the 1966 intake is unique in that it uses all 3 large base Rochester carbs unlike the 1965 which uses a small base center carb.
The 1966 also uses a different choke setup, it has a thermostatic choke coil that mounts directly on the exhaust crossover unlike the 1965 which uses choke tubes and a choke coil mounted on the carb itself.
So it’s not quite as simple as using an adapter plate.
Old 02-13-2023, 12:52 PM
Dick Boneske's Avatar
You can use the '66 aluminum repro intake. There are dual-mounting patttern Rochester 2 barrels used in big Pontiacs in the early '60's. I have several of them, which will bolt onto the '66 intake, but use the same choke, fuel lines, etc. as the '65 setup.
PM me for for details.
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 02-13-2023, 02:15 PM
dhcarguy's Avatar
dhcarguy dhcarguy is offline
Is this what you are referring to Dick.
ID:	607132   Click image for larger version
Old 02-13-2023, 02:17 PM
I think I'll just wait to find a '65. I want to port the intake runners to match my #48 heads and Fel Pro 1233 gasket, which I think are RAIV size. I want to leave the one on my car stock, so I'll get a new one to do the porting then swap it over.
1965 Pontiac GTO
9.25:1 CR
Stump Puller Cam
Old 02-13-2023, 06:14 PM
I have a few of the throttle bodies that would work to put your smaller center carb on a '66 intake without an adaptor. That would be the easiest way to go if you already have a '66 intake. If not, I have six '65 intakes if you can't find one.
FWIW, the venturi size on the "small" '65 center carb is actually larger than the OEM '66 center carb.--1.250" vs. 1.180". Obviously, the throttle plates are smaller on the '65, but the smallest restriction, the venturi's, are larger in '65.
BONESTOCK GOATS
Old 02-13-2023, 06:29 PM
I'll DM you Dick.
1965 Pontiac GTO
9.25:1 CR
Stump Puller Cam
Old 02-14-2023, 11:37 AM
pfilean's Avatar
pfilean pfilean is offline
I thought those double drilled bases were used on big cars when an "economy" option single carb was ordered, and it got a smaller venturi than even the 65 and earlier center carb.
Old 02-14-2023, 11:41 AM
You’re correct. Most of the “ economy carbs I have use the same 1.250” Venturi’s as the correct center ‘61 to ‘65 center carb.
In fact, the dual pattern base can be used with the correct Tri-Power center carb. You do need to use the “economy” fast idle cam assembly.
BONESTOCK GOATS
Old 02-14-2023, 02:57 PM
hobbygto65's Avatar
hobbygto65 hobbygto65 is online now
There is a 66 intake in the for sale section right now.
Old 02-20-2023, 08:58 AM
chrisp chrisp is offline
Have a few 66 intakes if any in need.
The Following User Says Thank You to chrisp For This Useful Post:
Old 03-02-2023, 05:36 PM
mike w mike w is offline
I would be interested in a 66 tripower intake. Feel free to call anytime.
Mike Wasson. 30.360.6385
Old 03-02-2023, 10:45 PM
Default 65 vs 66 Tri-power
309.360.6385
