Old 03-06-2023, 04:40 PM
1965 Pontiac Parisienne's Avatar
1965 Pontiac Parisienne 1965 Pontiac Parisienne is offline
Default 1966 Big car rear sway bar
Bought an 66 Pontiac Star Chief Coupé.. car has mount a big rear sway bar but it wasn’t correct screwed to the lower rear control arms ..
How will it mount correct ? Seems to be a 70’s seat bar …
Thx ✌️
ID:	608454   Click image for larger version
ID:	608455   Click image for larger version
ID:	608456   Click image for larger version
1965 Bonneville 2 door coupe nightwatch blue AZ car
1965 Bonneville convertible starlight black
1966 Star Chief Coupé
1965 canandian Parisienne custome sport convertible AZ car. „Sold“
1977 california Firebird Esprit [/SIZE][/FONT]
Old 03-06-2023, 06:16 PM
misterp266's Avatar
Check the photos on the Nitemare website. Not exactly the same as your bar but it mounts the same.
https://www.pbase.com/pontiac_perfor...tisway_bar_kit
That would be the proper way to mount it. I’m sure you could fab the required pieces. Hope that helps.
ID:	608470   Click image for larger version
" Darksiders Rule "
Old 03-06-2023, 09:49 PM
Rapdron's Avatar
Rapdron Rapdron is offline
Post Rear sway bar
The bracket slides into the lower rear control arms,.
You will need to test fit it and drill the bolt holes in your lower control arms to bolt them up.
These came on early 70's Grandvilles.
They really perform great,
I have used them in my past 2 66 full sized Pontiacs.
Combined with a 1 1/4" front sway bar, they greatly improve the handling and cornering on these big old cars.
You will definitely notice a huge difference in the ride.
Another Red Light Nightmare
1966 Martinique Bronze 2+2 428 tri-power auto, black top & bucket seat interior, pass recliner, ATC, Cruise, AM FM, Reverb, Wood wheel, tilt, ps, pb, pw
1966 Catalina, Barrier blue with a white vinyl top, tilt, AC, ps, pb, bucket seats with console 68 428 4 bolt, 4 speed M20 and a 66 tri-power project.
Semper Fi
Old 03-07-2023, 05:49 AM
Default Rear sway bar big cars
Thx for that ..yes I double checked the kind of mounting .. I will sandblast the parts and check for installing .. a rear sway bar is definitive a great performance ..done it to my 77 Firebird Esprit ..awesome change and new red adjustable Koni shocks
Old 03-07-2023, 04:02 PM
Just remember if you add a large rear sway bar without improving the front bar you may create an OVER steer condition. Not good.
Old 07-01-2023, 05:22 PM
MPKind's Avatar
MPKind MPKind is offline
Those 70s Pontiac B Body bars work fine on the 65-8 cars, but they do mount a bit more forward than the ideal location. My car is in the shop getting new rear control arms. The shop thinks they can source an aftermarket rear sway bar. Hilarious. No one makes one. PMT Fab makes a 61-4 but nothing newer. Frankly, my car turns pretty flat between the big Addco bar in front and the one I have in the back. Not sure about traction tho.
