The PO changed the seat upholstery from what is pictured below to 65 Gold upholstery. I prefer the color of the old upholstery and would like to dye the current upholstery to match it. However, I want to make sure I buy the correct dye. The color on the trim tag indicates 216 Saddle - based on the pics is that what it was? Or do they appear as light saddle?
A pic of current upholstery next to door panel also included. The arm rests are also 65 gold. One of the reasons I ask is Parts Place sells Saddle interior paint and it’s dark: https://www.thepartsplaceinc.com/par...keyword=saddle They also sell a Camel that looks like the old upholstery: https://www.thepartsplaceinc.com/pro...2-oz-can/75684 And a 1970 Saddle that looks like it too: https://www.thepartsplaceinc.com/pro...2-oz-can/75428 https://www.ebay.com/itm/35368128846...mis&media=COPY
Will Rivera '69 Firebird, 400/461, 290 Eddy D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '69 LeMans Vert, XS 350, #47 heads, TH400, 10 Bolt 3.23 gears, work in progress ‘66 Lemans, 455, 310 KRE D-Ports, HR 236/245, TH400, GV OD, 12 bolt 3.73 gears - see it here: https://youtu.be/RP_s1wJKm_Y?si=K0NZxoTyaGcj8Dcb Last edited by grivera; 03-18-2023 at 08:46 PM. |
I have researched this a bit - since I am restoring a car with the 216 interior (Light Saddle). From your picture - It looks like your door panels are still correct to the 1964 code and pattern. As far as I can tell this interior code is unique to 1964 - and other years Saddle or Camel will not match.
To make things worse - the current vinyl offerings are incorrect. I am in contact with Legendary and trying to get a more correct option. Here is a picture of piece of original vinyl from an area protected from the light (center), with SMS "original" material and Legendary's reproduction. As for dying your existing upholstery. I think you will have to have something made to match from the door panels. Hopefully this is helpful... |
Thanks - very helpful and discouraging that a suitable off the shelf color isn’t available. Thankfully my door panels appear correct and maybe will lead to a good match for the seats. I wish the PO hadn’t installed these seat covers. All but the drivers seat were in very nice condition - now gone.
Will Rivera '69 Firebird, 400/461, 290 Eddy D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '69 LeMans Vert, XS 350, #47 heads, TH400, 10 Bolt 3.23 gears, work in progress ‘66 Lemans, 455, 310 KRE D-Ports, HR 236/245, TH400, GV OD, 12 bolt 3.73 gears - see it here: https://youtu.be/RP_s1wJKm_Y?si=K0NZxoTyaGcj8Dcb |
The parts place dye matched my interior exactly (reproduction saddle) I needed to dye my boot cover.
M36 1970 Saddle Or S65 Saddle?
Will Rivera '69 Firebird, 400/461, 290 Eddy D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '69 LeMans Vert, XS 350, #47 heads, TH400, 10 Bolt 3.23 gears, work in progress ‘66 Lemans, 455, 310 KRE D-Ports, HR 236/245, TH400, GV OD, 12 bolt 3.73 gears - see it here: https://youtu.be/RP_s1wJKm_Y?si=K0NZxoTyaGcj8Dcb Last edited by grivera; 03-20-2023 at 10:15 AM. |
