Old 03-20-2023, 06:24 PM
SD455DJ SD455DJ is offline
Here's a picture (blurry...sorry) on the original PC emissions label from my '70 RAIII Formula 400. I can email this over to you Ken if you need it.
Dennis
Name:	'70 RAIII Formula Emissions Label.jpg
The Following 2 Users Say Thank You to SD455DJ For This Useful Post:
  #182
Old 03-20-2023, 07:36 PM
Verdoro 68's Avatar
New (old) toy arrived today - ALPS thermal printer for water slides. I just have to find a parallel to USB adapter (and then go from USB to USB-C) and the Mac driver.
Interesting setup with the tapes for each color. You can do full color with this printer and print spot colors too like metallics or white.
Ken
'74 Ventura 350
'69 AMC Javelin SST
  #183
Old 03-20-2023, 08:35 PM
dataway's Avatar
dataway dataway is offline
Are the tapes still available?
BTW, got my goodies today, thank you.
  #184
Old 03-20-2023, 08:59 PM
Verdoro 68's Avatar
They are readily available. There’s quite a hobbyist community around these printers for decals. Someone even made a Mac OS X driver for them.
Let me know how the screen works out for you!
Ken
'74 Ventura 350
'69 AMC Javelin SST
  #185
Old 03-20-2023, 09:32 PM
Held for Ransom's Avatar
Ken, I got my decals too. Thanks.
Possible NOS decals...
Dennis, you should order the Ames "correct" decal and compare. I don't have any later '70 to compare to.
ID:	609259   Click image for larger version
So long, farewell.
  #186
Old 03-20-2023, 09:40 PM
Shiny Shiny is offline
Wow, printing white is a testament to old tech.
That should be a great addition to your tools. I'm amazed you can get a driver that works in a modern OS... another bonus! Nicely purchased!
  #187
Old 03-20-2023, 10:34 PM
Trevor78 Trevor78 is offline
[QUOTE=Verdoro 68;6415352]I paused on the '70 labels and picked back up on the '67 HO and '68 Ram Air air cleaner screens since I had a few requests for them. These were tricky to get the size and the text right! First pass came out pretty decent.
That's very neat. Are they on dry transfer paper?
  #188
Old 03-20-2023, 11:01 PM
OG68 OG68 is offline
Received my decals today also. Thank you Ken.
  #189
Old 03-21-2023, 02:08 PM
Verdoro 68's Avatar
Modern is relative. I can't run the driver on my newer M1 MacBooks, but it does work on the older Intel machines. Fortunately, I have an old iMac that's slow as molasses but I think it will work perfect for this.
You can also do clear decals with an HP laser printer. There's a new company called Ghost that makes white toner but it isn't cheap. Another option to consider if this setup proves to cumbersome.
I just ordered a bunch of '69-'72 decals from Ames for reference - including the ones they list as correct. Interesting that they list a correct '71 455HO automatic decal but not a manual.
Those are silkscreened like the other air cleaner service instructions. I haven't done any dry transfers yet.
Ken
'74 Ventura 350
'69 AMC Javelin SST
  #190
Old 03-21-2023, 04:26 PM
unruhjonny's Avatar
I only noticed that today when this thread popped up;
LINK
I'm not sure how HFR knew about them, but I sure didn't - and even after I knew of them, I had to look in a specific manner for them to show up.
I was curious about these, and was considering buying one - but if you are going to put work into this decal type, I don't want to take away from your dedication to this;
Please let us all know about the deficiencies observed, or if you are going to crap-can working on 1970 decals because these ones are that good...
1970 Formula 400
  #191
Old 03-21-2023, 05:32 PM
Jonny,
We started posting about them in #168. I listed them in #169. I believe the "correct" part is referring to the squared off corners, more than the font, spacing and such. But, I can't compare as I have no later '70 vehicles. I am surprised that no early RAIV decals are out there.
Also, Classic Industries picture of the older PB decal (DT85 or DT0085 Osborn Reproduction number) shows squared corners, but I doubt they are.
So long, farewell.
  #192
Old 03-22-2023, 01:19 PM
Verdoro 68's Avatar
I'll make a call when I get the decals and we can compare. Sounds like there's a need for at least one correct '70 that's not being produced today though.
On a different note, I could use some help deciphering coolant decal usage. I purchased an NOS decal with the p/n 9781477.
Based on some internet research, it looks like the coolant part number was changed from 983743 to 1050030 in '68 so that's part of the puzzle.
The other part I'm trying to figure out is the sizes. When creating the black coolant decals, I got measurements off an original (2"x4.5"). I also have pics of a white decal that's the same size. However, the NOS decal I purchased is 2.25" x 5" - like the current reproduction. Anyone have any insight into the size usage? I can't find a reference to the part number of the NOS decal anywhere so I'm not sure what it was used on.
Interestingly, it also looks like the line art is thinner on the white version. Pic below has the black decal I created, the existing repro on the market and the NOS on the bottom.
ID:	609374   Click image for larger version
ID:	609375   Click image for larger version
ID:	609376   Click image for larger version
Ken
'74 Ventura 350
'69 AMC Javelin SST
  #193
Old 03-22-2023, 02:37 PM
It's clear to me your design quality is 3 notches above GM.
Staring at the 3 you just posted, I had to wonder what kind of day the original designer was having when he or she layed out the text in the box "If hot water only...".
Any idea if there was a "graphics design" function or department? Maybe they had the cooling system engineers make their own decals? My guess is on the latter back then.
In my former life, something as seemingly simple as a label could require design input and approval by at least 3 different organizations and need to be tested/verified by 2 or more different orgs. It was even worse if the labeling had regulatory content. If the labeling was molded into a part, a major storm could erupt if a change was needed last minute.
  #194
Old 03-24-2023, 12:56 AM
Verdoro 68's Avatar
Get ready for the $125 "concours correct" decal extravaganza!
Hot take: none of these are correct. I can tell by looking at the fonts. Quality and finish is variable on them. Ames part numbers follow the descriptions.
'69 Ram Air IV PD (X795JA)
Matte finish, 3-1/4"x 5-7/8", squared corners
'70 400 4BBL PC (X185BA)
Semi-gloss finish, 3-1/8" x 5-11/16"
Original PC decal
'70 455 4BBL PD (X239A)
Semi-gloss finish, 3-1/4" x 5-3/4"
'70 Ram Air IV PE (X350A)
Matte finish, 3-1/4"x6", squared corners
All the '70s together
ID:	609572   Click image for larger version
ID:	609573   Click image for larger version
ID:	609574   Click image for larger version
ID:	609575   Click image for larger version
Ken
'74 Ventura 350
'69 AMC Javelin SST
  #195
Old 03-24-2023, 01:06 AM
Verdoro 68's Avatar
'71 455 HO manual PM version I just made (top) vs. '71 455 HO manual PM (X181 - bottom)
Gloss finish, 2-1/2" x 6-3/4"
'71 455 HO automatic PN (X191A)
Matte finish, 2-5/8" x 6-5/8"
'72 400 PG (X202)
Gloss finish, 2-5/8" x 6-11/16"
'72 400 PE (X167)
Semi-gloss, 2-9/16" x 6-9/16"
ID:	609577   Click image for larger version
ID:	609578   Click image for larger version
ID:	609579   Click image for larger version
Ken
'74 Ventura 350
'69 AMC Javelin SST
  #196
Old 03-26-2023, 06:38 PM
Verdoro 68's Avatar
Given the state of the concours decals, I picked back up on the '70s and I think I have the PC label in a pretty good state.
Alignment with the original....
The original Dennis provided above:
Comparison of my version and the Ames version.
ID:	609757   Click image for larger version
ID:	609760   Click image for larger version
ID:	609765   Click image for larger version
Ken
'74 Ventura 350
'69 AMC Javelin SST
The Following 3 Users Say Thank You to Verdoro 68 For This Useful Post:
  #197
Old 03-26-2023, 08:29 PM
I'd like to see a few lines fattened up and some lines shortened up and the degree sign after the 9 elongated. Compare to the supposed NOS decal post 185.
So long, farewell.
  #198
Old 03-27-2023, 12:38 AM
Verdoro 68's Avatar
Fixed the degree sign, not sure how I missed that one. Could you elaborate on the lines? I see the bottom left two are a little shorter. Which ones do you think need to be thicker? It's hard to tell via the pic but maybe the left far left on the tune up specs and the line under Pontiac Motor Div.
Ken
'74 Ventura 350
'69 AMC Javelin SST
  #199
Old 03-27-2023, 10:03 AM
unruhjonny's Avatar
there should be a gap between the bottom line and the bottom of the sticker too - right?
1970 Formula 400
  #200
Old 03-27-2023, 12:38 PM
Verdoro 68's Avatar
Yes, although it looks like the width of that gap was variable.
Ken
'74 Ventura 350
'69 AMC Javelin SST
