Old 07-10-2023, 07:47 AM
rt400 rt400 is offline
Default ELECTRICAL ISSUES
Advice appreciated. 1968 GTO with factory gauges. When turn signal is on, oil pressure and water temp gauge needles flicker with the blinking of flasher?
Thanks in advance.
Old 07-10-2023, 08:49 AM
JSchmitz's Avatar
JSchmitz JSchmitz is offline
Sounds like a bad ground.
Old 07-10-2023, 09:25 AM
1969GiPper 1969GiPper is offline
Thanks in advance.
When you say “with factory gauges” do you mean the gauges were installed at the factory or someone installed factory gauges to replace factory warning lights?
I ask this because converting warning lights to gauges requires a couple of changes to the wiring harness.
Old 07-10-2023, 11:57 AM
OG68 OG68 is offline
Ground straps for a 68 gauge panel
Old 07-10-2023, 12:10 PM
Boy, that's a might pretty instrument panel Ed!
Old 07-10-2023, 01:37 PM
1969GiPper
They are factory installed gauges. Thanks
Old 07-10-2023, 02:21 PM
Courtesy of Pete Serio.
Old 07-24-2023, 12:26 AM
Vid's Avatar
Vid Vid is offline
Easy fix, just drive like 99% of the population and don’t use turn signals! Haha sorry but you left the door open for that joke
Old 07-27-2023, 12:36 PM
It is a ground issue but I find some cars will still have the gauges bounce (and shift when lights are on) even if you have good cluster case grounding, maybe also a ground problem in the printed circuit itself or even the gauges themself.
