Old 01-29-2023, 03:49 PM
cnc's Avatar
cnc cnc is offline
Dash installed finally, new heater control cables (EZ Slider ) then I placed the pass side kick panel in place bit of a beotch to install....that wa the side I had to fix the cable for the upper dash vent as it blew into a few pieces….I used a piece of vacuum line sliced one side of it slipped it over the cable and then tie strapped it to close up the slit works perfect….thought I had a pic but I don’t…
Next I'm gonna pull the carpet out that's been laying in there then lay down the low profile x mat
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best [email protected] Lookin for 11's
  #42
Old 02-26-2023, 03:06 PM
cnc's Avatar
cnc cnc is offline
Xmat is down for the frt section and need to do the rear and see what's left..this is just the pass side
The Following User Says Thank You to cnc For This Useful Post:
  #43
Old 02-28-2023, 04:16 AM
Formulabruce's Avatar
The headliner will test your patience. I custom ordered a '74 with NO rear shoulder harness cut outs. Still needs a lot of messing with.
" Long may we DRIVE !"
  #44
Old 02-28-2023, 08:18 AM
cnc's Avatar
cnc cnc is offline
Yeah that's the last thing on my list.. .I need to choose a headliner for material....need to go back through and see who it was I was looking at..Bruce did u get the abs backer or stick with the cardboard....my board is still in good condition
  #45
Old 02-28-2023, 10:02 AM
78w72 78w72 is offline
the perforated vinyl ABS backed 1 piece headliner with no seatbelt cutouts is not a custom order, PUI has a part# you can use to order through summit, i bought one for my 72 since i like that style more than the original fabric style in earlier cars, have yet to install it though since it needs some custom trimming of the front/rear metal trim and adapting the plastic side trims to a car that used the metal type. I have the part # if you decide to go that route.
but if youre cardboard backer is in good shape its better to use that, it will fit much better and you just need to buy the roll of perf vinyl to glue to the cardboard.
  #46
Old 02-28-2023, 01:31 PM
the previous owner opted for the perforated - it looks good however what goes up must come down....she's starting to sag
Looking forward to you continuous build thread...
  #47
Old 02-28-2023, 03:22 PM
You are right, the first one I orders years ago was a custom order from PUI, and I think I may have been the first.
Ames sells the material to repair these and I like the 3m brand extra hold spray glue.
  #48
Old 02-28-2023, 04:20 PM
i saw the ABS no seatbelt headliner mentioned on here years ago so it may have been from you. mine is still unopened sitting in my basement, was focused on getting the engine built & installed as well as car painted before final interior things, hope to get to it this season.
i used the original cardboard backer in my 81 & glued new padded back perf vinyl to it, turned out excellent. i used the 3m spray glue too, has held up for 12 years now with no signs of sagging.
  #49
Old 02-28-2023, 10:38 PM
cnc's Avatar
cnc cnc is offline
Here is what my headliner looks like on the right and this is what I’ve found similar but from what I’ve seen it’s 74 and up…
Either of u gentleman have a pic of the adhesive or more specifics of the adhesive I know there are a few out there…
ID:	608128   Click image for larger version
  #50
Old 03-10-2023, 08:30 PM
cnc's Avatar
cnc cnc is offline
So getting around to installing window sweeps on the door...this car has the decor package.. soooodoes this seal sit like I have it so the actual decor lip is just over the rubber
  #51
Old 03-10-2023, 10:28 PM
cnc's Avatar
cnc cnc is offline
Pics below…don’t recall where I got these sweeps but they seem to fit like sh*t….I’m gonna have to elongate holes and actually drill another hole beside another No big deal just more time…what ya want for aftermarket
ID:	608677   Click image for larger version
  #52
Old 03-10-2023, 11:58 PM
Big Bear's Avatar
Big Bear Big Bear is offline
From the reserch I did on the glue to attach the headliner , it seems most preferred Weldwood Landau top & Trim Adhesive. It's for high temp, so should withstand the summer heat with out releasing. Bought the headliner material from Ames. Looks to be good quality.
  #53
Old 05-08-2023, 09:43 PM
cnc's Avatar
cnc cnc is offline
Well doing some more stuff to the car slowly but surely ...I've come up with planter fasciitis dam is that painful...hobbling round at work then coming home to work on the car is not in my best interest but I got out to the car ..primed the engine installed valve covers with fresh gaskets, put fresh gas in, dropped the dist in, filled the cooling system added some trans fluid fired right up....good feeling after more than 2 years
  #54
Old 05-08-2023, 10:56 PM
77 TRASHCAN's Avatar
Yeeee Haaaa!!!
Glad to hear the Great Pumpkin is getting closer!!!
I got a steroid shot in one of my heals, THAT made me cry!!! It did help a lot, though...
I worked on my feet, way too much back then, thankfully don't now.
Looking forward to pictures, as always!!!
Jeff
Shut it off
Shut it off
  #55
Old 07-24-2023, 10:55 PM
cnc's Avatar
cnc cnc is offline
Well had new frt windshield installed and the original rear windshield installed ...saved the sticker on the rear glass from Portland University
Door panels installed next will be rear seat final install and trim the insulation...read parcel shelf panel I may keep which has already been changed out but kinda wavy.... then the rear side panels...still need to decide in material for headliner ...Cardboard headliner is still good condition...so need to look into it...
  #56
Old 07-25-2023, 06:13 PM
gtospieg gtospieg is offline
Cool that you saved the sticker....I'm still using my somewhat less than great rearview mirror on my restored 67 GTO (Fremont car)because it has a sticker on the back from some college in Ca..... Some lucky kid was driving a 67 GTO in college.
  #57
Old 09-10-2023, 05:53 PM
JUDGE3 JUDGE3 is offline
where ya at on this beauty CNC? need more pics and updates. eager to read somebody else's thread !
  #58
Old 09-10-2023, 08:44 PM
grd777 grd777 is offline
looks great . want to install my front and rear glass next week
  #59
Old 09-16-2023, 01:09 PM
cnc's Avatar
cnc cnc is offline
Ok couple pics car is basically done aside from stripes and some chrome trim
ID:	620076   Click image for larger version
ID:	620077   Click image for larger version
ID:	620078   Click image for larger version
  #60
Old 09-16-2023, 01:24 PM
cnc's Avatar
cnc cnc is offline
Couple more
ID:	620082   Click image for larger version
ID:	620083   Click image for larger version
ID:	620084   Click image for larger version
