Old 08-22-2023, 05:34 PM
Johnny406's Avatar
Johnny406 Johnny406 is offline
Default 78 Firebird tail light harness wires identification
I'm installing a used factory taillight harness in my 78 to replace the wiring mess back there to get the rear lights working for the first time in many many years.
The car is a race car that I'm trying to make a little streetable.
This is the harness end of the new harness I'm installing. I know:
Yellow: left signals
dark green: right signals
light green: reverse lights
What I don't know is
pink wire? Perhaps trunk release???
brown wire: Is it tail light, or brake light? What wire for the one missing/ to the brake light switch?
THANK YOU!!
Name:	taill light harness.jpg
Johnny US Army Retired
1978 T/A 463 Pontiac, KRE 74cc 300CFM D-ports, Howard's custom SFT, Nash Intake,QFT 950 E85 carb, TCI TH-350, 4200 converter 3.73 12 bolt [email protected]
1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car.
1972 LeMans 350 Pontiac H/S Drags project
Old 08-22-2023, 08:06 PM
Trevor78 Trevor78 is offline
Do you have a wiring diagram?
Fuel sender.
The Following User Says Thank You to Trevor78 For This Useful Post:
Old 08-22-2023, 09:48 PM
bhill86's Avatar
bhill86 bhill86 is offline
Signal wires double as brake light wires. Those come from the turn signal switch in the column. Pink is fuel sender as mentioned and brown is parking light circuit.
1977 Trans Am 400/4speed (swap)
Brian
The Following User Says Thank You to bhill86 For This Useful Post:
Old 08-22-2023, 10:33 PM
Johnny406's Avatar
Fuel sender.
Not yet
Old 08-22-2023, 10:35 PM
Johnny406's Avatar
Thank you!! That helps a lot as I have a universal turn signal switch/arm for the race car steering column. Now I just need a flasher and a couple of hours...
Old 08-23-2023, 03:54 AM
Check your PM, will send you a copy of diagram.
Old 08-28-2023, 12:45 AM
You got the email?
