Old 10-15-2023, 09:56 AM
RFCOLEMAN RFCOLEMAN is offline
Default 1971 GTO Grilles, what could have been.
I have a 1971 GTO. One of the things I was always disappointed with was the grilles. They look flat and plain compared to all the other years designs.
So I decided to do something about it. I took a pair of 1972 GTO grille bezels and painted the inside semi-gloss black. Then I cut and fit a pair of 71 GTO grille mesh. As you can see from the pictures below, I believe it gives the front view some depth, more in line with most Pontiac designs.
What do you all think?
Left Twix, or Right Twix?
ID:	621714   Click image for larger version
ID:	621715   Click image for larger version
ID:	621716   Click image for larger version
ID:	621717   Click image for larger version
Old 10-15-2023, 10:20 AM
JSuchma JSuchma is offline
I definitely agree. I too, also wondered what happened when Pontiac designed the 71 GTO grilles. They are in no way in line with other Pontiac grille designs.
The Following User Says Thank You to JSuchma For This Useful Post:
Old 10-15-2023, 11:06 AM
indymanjoe's Avatar
x's 3
right twix all the way!
I am the Thread Killer!
Old 10-15-2023, 11:17 AM
A good look for a lightly modified car, esp with the black painted grille bezels & the '72 parking lamp ornaments. The flush mount dull silver mesh inserts in the '71 GTO grilles always bothered me as well. The black mesh inserts in the '71 Judge grilles are at least palatable. Am glad the styling dept had a chance to clean things up some with the '72's. Esp for a model that wasn't supposed to be!
Old 10-16-2023, 03:56 PM
pggto's Avatar
pggto pggto is offline
I like it! Still has a 71 flare without just looking 72.
Old 10-17-2023, 12:16 AM
Mister Pontiac's Avatar
Mister Pontiac Mister Pontiac is offline
As OPH said, the blacked out Judge grills are the better choice look for 71 (I did mine that way), but I like your take too. Go with what you like!
I put 74 Catalina grill inserts in my 74 Bonneville because I preferred the look too, so I totally understand going with what you like
Indeed, Pontiac dropped the styling ball on the standard 71 grills.
Eric Mitten
'74 Bonneville 4dr Sedan (455/TH400/2.93 open)
'72 LeMans GT (455/M-13/3.23 [8.5"] posi)
'71 GTO Hardtop (400/TH400/3.07 12 bolt posi)
‘71 GTO Convertible (455HO/TH400/3.23 posi)
'67 GTO Coupe (455/ST-10/2.93 posi)
Deuteronomy 8:3
