Old 11-18-2023, 09:30 PM
graygator graygator is offline
Default How long is the intermediate steering shaft on a 1969 GTO/Lemans?
I just tried to reinstall the steering column in my 69 Lemans convertible. See the photos. The upper column support bracket slot comes up a little short. And while wrestling and pulling on the column I managed to break one of the die cast inserts. The upper column looks fine and does not appear to be collapsed. I assume the intermediate shaft is slightly collapsed. This car has power steering and also has a new rag joint.
Does anyone have a known good intermediate shaft that you could take a length measurement on?
I've had this column in and out several times and don't recall it being a problem before. But I did stand the whole assembly, upper and intermediate shafts, on end recently. I had just painted the upper column and installed a new turn indicator switch. Then I stood the whole assembly on end while I installed the column lock plate and keeper ring. Hmmm.
Anyone know where I can buy just the die cast insert, like I broke?
ID:	623442   Click image for larger version
Kent R.
Old 11-19-2023, 03:11 PM
Upon further inspection and research:
The upper column was collapsed 1/2" to 3/4". Images found on the internet showed almost no shaft visible beyond the spines at the bottom of the upper column. Mine had 1/2" to 3/4". Similar evidence was observed based on the location of the position feedback lever which interacts with the column locking mechanism. I was able to pry the inner tube out of the outer tube by this amount.
You can't typically buy just the die cast inserts because they held in place with injected plastic to hold them in the upper column support bracket. When you have a wreck and are thrown into the steering wheel the plastic shears and the bracket slides forward out of the die cast inserts which are bolted to the dash bracket. The plastic in both die cast inserts were previously sheared on my car. See image below.
This car was wrecked sometime in the distant past, based on several other pieces of evidence. Frame was straightened before I got it and again during my restoration (it wasn't right).
The lower or intermediate steering column must have been collapsed by a similar amount. It is moving back to what I assume is the original length relatively easily.
Guess I'll be buying a replacement bracket, complete with inserts from Ames.
Kent R.
Old 11-19-2023, 04:22 PM
OG68 OG68 is offline
You may want to disassemble the column and inspect for further damage. On the previous generation of collapsible column (67-68) there are injected plastic inserts that hold the inner tubes together and another on the actual shaft itself. Upon impact that plastic piece shears away allowing the inner column and shaft to collapse.
I can't say the 69 and up column has the same thing but it may be worth your while to take a look, now that the column is out.
Old 11-19-2023, 09:51 PM
Tuske427's Avatar
Tuske427 Tuske427 is offline
Maybe give Frank a call/ email. Seems he has columns available with these parts included. He might have them separately, too? https://frankspontiacparts.com/usedparts/gtoparts2.htm
Long live the Muscle Car
Instagram @tuske427
1967 Firebird #BVbird
1967 Firebird 400 4 speed project
1969 Verdoro green GTO (daily)
Old 10-10-2025, 05:32 PM
Tim66 Tim66 is offline
Send a message via ICQ to Tim66
Default intermediate shaft
17 1/2 " Does anyone know what kind of grease to use in boot at end of shaft?
Thank you,Tim
