Old 11-27-2021, 03:27 PM
mysticmissle's Avatar
with enough money im sure they can run with any of them. they are a budget higher performance head in my opinion. if you're trying to make 600 or more there are better options in my opinion. but to refurbish a set of iron d port heads these are a better alternative in my opinion as long as you don't mind buying headers or manifolds except for the chinesium which can be found in almost everything if you look hard enough, cranks, rods, etc
  #122
Old 11-27-2021, 06:05 PM
Jack P. Jack P. is offline
I talked to Speedmaster, they have 29 orders for Pontiac heads so far. If you want the CNC ported version the part number is PCE281.1801 and they are the bare heads version costing $958 each. I ordered a bare set as I am not sure of my direction yet.
  #123
Old 11-28-2021, 10:15 AM
ponjohn's Avatar
ponjohn ponjohn is offline
What do they flow?
  #124
Old 11-28-2021, 12:09 PM
Sirrotica's Avatar
Originally Posted by ponjohn View Post
What do they flow?
The guy in the youtube link I posted says, Speedmaster claims, 295 Intake, 202 exhaust. out of the box. From his reaction when he disassembles the heads I think he was dubious of those figures, and talks about the bowls needing blending better than the example he was scrutinizing in front of him.
Here's the 18.18 minute video review:
https://www.youtube.com/watch?v=fFfPEjG0uCc
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
  #125
Old 11-28-2021, 12:11 PM
slowbird's Avatar
slowbird slowbird is offline
I don't see that p/n anywhere, got anymore info on them?
  #126
Old 11-28-2021, 01:33 PM
rustedgoat rustedgoat is offline
Black Friday ends in 14hrs
So for a basic street build
72cc
350 9:1 are the runners too big?
400 10:1 best application
455 11.25:1 is compression to much for pump gas?
"Honestly the car will only be there for a few weeks, OK maybe a month at the most"
  #127
Old 11-28-2021, 02:19 PM
He told me I could type in that number and get all the info and even order if I like. I don't see it
so I wish I asked for the numbers when we talked. My GUESS would be around 310 intake but I'm usually wrong. Sorry.
  #128
Old 11-28-2021, 05:10 PM
68hotbird 68hotbird is offline
Default 461 speedmaster combo
I built a 461 with the speedmaster heads. I used the bare castings installed 2.19 SI intake and 1.77 SI exhaust valves ra4 length. I had the bowls cut on the Serdi with the valve job and did some blending in the bowls. I smoothed out the pushrod bulge and opened the port up to match the cnc opening. I have some pictures if anyone is interested. It has a Howards 237/243 hydraulic roller 1.65 rockers and a torker 2 port matched to the heads. It sounds really good. Have not had it to the track yet but hoping for 550-575 hp. I don't have any access to a flow bench close to me but based on my ported edelbrocks I see no reason with this porting and the larger valves these heads won't flow 315-320 on the intake.
The Following User Says Thank You to 68hotbird For This Useful Post:
  #129
Old 11-28-2021, 05:20 PM
Default porting pictures
here a few of the finished ports. The last picture is of the as received intake port opening. The cnc entrance shape and dimension is actually very good. This was just some basic clean up and bowl work that is easy to do. There is a lot of room to raise the roof some for an all out racing deal if you wanted to go that far with these heads.
ID:	578748   Click image for larger version
ID:	578749   Click image for larger version
ID:	578750   Click image for larger version
  #130
Old 11-28-2021, 10:17 PM
How much did you open pushrod holes for 1.65 rockers?
  #131
Old 11-29-2021, 10:15 AM
Default pushrod holes
With my setup which is ra4 length valves and harland sharp 1.65 rockers no modifications were needed to the pushrod holes for clearance.
  #132
Old 11-29-2021, 09:25 PM
we used 1.65 rockers and 5/16'' pushrods with no issue also. about 600 lift net
The Following User Says Thank You to mysticmissle For This Useful Post:
  #133
Old 01-14-2022, 11:10 PM
BLANK1's Avatar
BLANK1 BLANK1 is offline
Friend of mine Dave Hoover just installed Speedmaster heads on his 474 in his 64 Tempest. Was having some issues with his E heads so he got a set of Speedmasters from Randy Repp. Only thing done to them was the valve springs were changed. Motor has a 240/254 @.050 .390 lobe lift 112 LSA hyd. roller, stock Torker II and a Vortech supercharger. Ran his best 1/8 th mile time of 6.24 and equaled his mph of 112. His Eheads were ported and had 2.11/1.77 valves. He's down in Louisiana at No Problem Raceway this weekend. The race is on MotormaniaTV. He is pleased with the performance of the heads.
The Following User Says Thank You to BLANK1 For This Useful Post:
  #134
Old 01-15-2022, 11:11 AM
ponjohn's Avatar
What was wrong with the E-Heads?
  #135
Old 01-15-2022, 12:33 PM
Leaking water
  #136
Old 01-15-2022, 01:09 PM
BLANK1's Avatar
Ponjohn,
  #137
Old 02-28-2023, 03:31 AM
blueghoast's Avatar
Default Speedmaster heads
Here it is
GT
The Following User Says Thank You to blueghoast For This Useful Post:
  #138
Old 01-01-2024, 03:33 PM
Tim Corcoran's Avatar
Just to clarify, the SM heads are designed in Austraila, cast in China, machined and assembled in California. You can call them, they will answer questions and you can order over the phone or online. They are not made by Pro Comp as some have said.
Tim Corcoran
  #139
Old 01-01-2024, 05:04 PM
slowbird's Avatar
What design work went into them, lol. I think you mean they were copied in Australia
The Following User Says Thank You to slowbird For This Useful Post:
  #140
Old 01-01-2024, 05:28 PM
Stan Weiss's Avatar
If you do a Google search for Speed Master and Pro Comp Electronics while they don't have the same phone number they do have the same address. 1101 W Rialto Ave
Stan
Pontiac Pump Gas List
